| diyAudio Sponsor | ||
Hello all,
I'm trying to build a very large current sink as a type of inrush limiter. My idea was to use something along the lines of the BUF420M, grounding the emitter, setting up an adjustable voltage divider for the base, and pulling a couple hundred MA of current through the collector. The plan is to use this between the ground and the CT on my power transformer, keeping the power supply somewhat confined. Any ideas? (320v B+) Here is the data sheet: http://www.st.com/stonline/books/pdf/docs/5063.pdf What kind of voltage would you all expect across this guy? Any decrease in rectified B+? Best to bypass it with a cap? |
#2 |
Beware. All bipolar transistors suffer from a condition called "secondary breakdown". For most transistors this is the primary failure mode in linear operation. This limits the power dissipated by the device in linear mode. Most transistors have a chart showing the "SOA" (safe operating area) for several duty cycles and DC. These are not shown for this device. Only data for short pulse (.2uS). This device will probably die in your application.
I built a device similar to what you describe. I used a mosfet (no secondary breakdown) and drove it with the PWM output of a PIC chip. The pulse width is narrow at turn on gradually widening until the fet was fully turned on. A fully on fet drops about a volt in my system. You could do this with a 555 chip instead of the PIC chip.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#3 |
Do you happen to have a schematic for your setup? So even if I'm running this guy conservatively (200ma) and not exposing it to high voltage, it will still break down?
| Any clue of how to use this part as a current sink for a CF? | G | Tubes / Valves | 36 | 19th July 2006 08:35 AM |
| Does the PCM1794 sink or source current? | Rescue Toaster | Digital Source | 0 | 17th September 2005 08:53 AM |
| Pentode current sink | ABJ | Tubes / Valves | 14 | 23rd January 2005 10:56 PM |
| Using Ixys current regulator as current sink. | G | Solid State | 3 | 16th November 2002 11:23 AM |
| Help with Current Sink | RichardJones | Pass Labs | 1 | 31st January 2002 05:52 PM |
| Page generated in 0.06598 seconds (71.63% PHP - 28.37% MySQL) with 10 queries |
