diyAudio Sponsor
Closed Thread
Old 12th September 2008, 09:42 PM   #1
Default Direct from the mains?
I live in a country with around 240V ac as mains power. I notice that some PSU for small signal tube circuits require around that voltage prior to retification/sabilization etc.. Given that we get 240ac straight "out of the tap", is it possible to dispense with the power supply transformer in these designs? Now be polite please. There may well be very good and obvious technical/legal/safety reasons etc.... it is just an innocent enquiry....ok?
I think my negative ion generator (built from a local mag' design) does this.
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse.
Old 12th September 2008, 10:24 PM   #2
diyAudio Moderator Emeritus
ray_moth's Avatar
Jonathan,
This is not meant as a flame, but in a DIY forum such as this no one with any sense of responsibility is going to agree with doing what you suggest. It's dangerous (and possibly illegal where you live, anyway). If you do a search you'll find it has been discussed here already.
Bottom line: always use a transformer, even if it's only a 1:1 isolation transformer to give the same voltage as the mains.
Old 12th September 2008, 10:36 PM   #3
SY's Avatar
It is DEADLY DANGEROUS. Don't even think about it. That's why we have a forum rule against it.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Closed Thread
Direct (or almost direct) replacement for Morel MW144? mr_push_pull Multi-Way 1 19th April 2009 04:43 PM
40% Tap direct to plate GlidingDutchman Tubes / Valves 9 12th July 2008 09:15 PM
MAINS... simple, old style amplifier, plugged into mains electrical outlet (110) destroyer X Solid State 2 15th June 2008 02:31 PM
Direct Mains Operated High Power Amplifier FACTOR Solid State 4 27th December 2003 11:54 AM
Page generated in 0.07649 seconds (66.51% PHP - 33.49% MySQL) with 10 queries
