Annealed silicon core opt`s
Old 12th September 2008, 04:34 PM   #1
noyan is offline noyan  Turkey
Send a message via Yahoo to noyan
Default Annealed silicon core opt`s
Do you have any idea about annealed silicon iron? For example good wound EI shaped annealed silicon iron output transformer how will sound?
Old 13th September 2008, 10:14 AM   #2
Tweeker is offline Tweeker  United States
Silicon steel for quality power and audio transformer applications is typically annealed.
SELECTION OF ELECTRICAL STEELS FOR Magnetic Cores
Reannealing will damage any organic insulation between the laminations if present.
Be sure your foil hat has a good low impedance ground.
Old 14th September 2008, 07:02 AM   #3
Thank you for your answer.
Annealed silicon core opt`sHide this!Advertise here!
AIR-Core Vs Ferrite-Core Inductor in Class-D amplifiers Workhorse Solid State 14 4th April 2016 02:26 PM
inductor/choke/air core/ferrite core. . . same thing? poolorpond Pass Labs 24 29th March 2008 11:55 PM
Grain oriented silicon steel core data needed eppidei Tubes / Valves 0 14th September 2007 03:08 AM
Solen Air core inductors, Hammond Iron core. gnomus Swap Meet 0 30th July 2004 02:28 AM
Any website reference for diy choke ,siliver R-core, C-core, EI and power transformer bmpa Parts 2 22nd April 2004 05:15 AM
Copyright ©1999-2017 diyAudio
