| diyAudio Sponsor | ||
I've asked this over on AA but thought I would ask here as well.. I have been experimenting with one of my jelabs300b mono block amps today and thought I would try DC on the 6sn7 driver to see if it would remove the last bit of hum. Keep in mind that I am rather the novice when it comes to electronics. Anyhow, I created the supply using a SS full wave rectifier, .2 ohm resistor and a 10,000uf cap. I attached the positive and negative leads to the filament of the 6sn7. Voltage is about right at 6.23 volts. However, when I fire up the amp, I get a really bad hum. Not sure I did this correctly? What am I missing? Do I need to ground one leg of the supply? Any help with this would be most appreciated. Regards, Danny |
#2 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
10K mikes of capacitance isn't enough to hold the ripple down enough to keep some forms of AC off the line. Schematics please??
Let me do the numbers....MJ..I'll get my book, OK? ________________________________________Rick...... .. |
#3 | |
Before you try any of that, I would suggest that you try AC again, but lifting the heater reference about 20-30V above ground. This is done with a voltage divider from B+ to ground. Let's say your B+ is 300V. Assuming a bleeder resistor of 200k, you'd use something between 20-30k between the 200k and ground. Connect a 10uf cap from that point to ground, and from that point to one heater leg. You won't need DC for a driver, unless you have a poor tube. Sheldon |
#4 |
What's this DC supply referenced to? If it's floating with respect to everything else, that could be your culprit.
If it's not, make sure that you've used sane grounding practices. Also, I agree that 10,000uF / 0.2 ohms is probably an insufficient filter to smooth 60Hz AC. Increase your capacitance. Also, an RF choke may remove any high-frequency switching artifacts introduced by your rectifier. -k |
#5 |
Well, a couple things:
1- If you built the JE Labs 300B amp in stock trim (at least from the schematic I've seen) it uses AC for the 300B filament. So if this is the case, you'll never get the hum balanced out with these. The 300B really needs a DC filament to be quiet. 2- A good 6SN7 should be quiet with AC filaments, but as pointed out already, you should reference it to ground either via a center-tap on the winding or a pair of resistors (I prefer 30ohm 1%). Alternately, if you are having some filament/cathode voltage issues (or want a safety margin) you can make the divider network and "lift" the filaments off of ground. Regards, KM Note: full-wave rectified DC will have 120Hz ripple, not 60Hz. |
#6 |
My mistake. 10000uF / 0.2 ohm yields a corner frequency around 79 Hz. It'll kill 120Hz hum pretty significantly.
#7 |
Hi Kmaier, Sheldon,
You're correct about the humming 300B Anyhow, Sheldon makes a good case for elevating the filament on the driver. I think I will give that a try before doing anything else... Thanks to all for your input and I will let you know how it turns out.. Regards, Danny |
#8 |
I always put a mute switch on my DHT SE designs... simply grounds the grid of the output tube, be it a 45, 2A3 or 300B. This easily allows you to fine tune the hum balance pot and also determine what hum level is coming in from the input/driver stages, along with a shorting input plug.
Have you measured the total output noise of the amplifier? Regards, KM |
#9 |
Hi Sheldon,
I built the voltage divider circuit and have about 35 volts. If I connect it to one of the heater legs it doesn't seem to make much difference. One thing I am confused about, my AC winding has a center tap to ground, instead of connecting to a heater leg, should I connect the CT to the voltage divider instead? Regards, Danny |
#10 |
Yes, in that case, use the center tap to your divider. If that doesn't reduce your hum, it's not the driver filament. I have an 801 amp with 6SN7 driver. AC on the driver, Tentlabs for the DHT. It has no hum on 106dB speakers - none. Schematic, pictures? Let's have a look at your power supply and grounding scheme.
sheldon |
| My new old amp hums | Pbassred | Solid State | 1 | 15th June 2008 12:19 AM |
| GC hums with separated PS | wchick | Chip Amps | 1 | 6th May 2007 10:09 AM |
| Can you see why this amp hums? | paulspencer | Chip Amps | 5 | 5th March 2007 11:19 AM |
| SI T-Amp: getting rid of PSU hisses and hums | Livino | Class D | 0 | 5th October 2005 06:31 PM |
| Page generated in 0.10054 seconds (88.94% PHP - 11.06% MySQL) with 10 queries |
