diyAudio Sponsor
Old 11th September 2008, 12:00 AM   #1
Send a message via AIM to audiowize
Default triple triode common cathode - only want to use 2 triodes
Hello all,
I would like to use the 6MN8, but only 2 of the triodes (diff amp). What can I do with the other grid/plate to totally keep them out of the equation? Since I'm running fixed bias, maybe I run the raw B- to the 3rd grid and tie the plate to one of the other two, or to the raw regulated driver supply (-85v on the grid should prevent any significant current draw). Any thoughts?
Old 11th September 2008, 12:16 AM   #2
You dont really need to do anything to it. You can leave the 3rd grid and the 3rd plate open. No 'extra' current will flow if the plate is open.
Robert McLean
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 01:37 AM
Why not so common to split dual triodes between channels? leadbelly Tubes / Valves 8 7th April 2007 01:42 AM
cmrr of common cathode metebalci Tubes / Valves 14 21st August 2004 08:25 PM
cathode connection in directly heated triodes metebalci Tubes / Valves 2 21st March 2004 09:58 PM
Common-cathode triode vs source-follower Hexfet. Circlotron Analogue Source 14 22nd March 2003 08:35 AM
Page generated in 0.07302 seconds (66.00% PHP - 34.00% MySQL) with 10 queries
