Keep Blowing Fuses
Keep Blowing Fuses
Old 10th September 2008, 11:33 AM   #1
Whiting is offline Whiting  Australia
Default Keep Blowing Fuses
Hi All
Can anyone please help with suggestions as to why the amp keeps blowing fuses on power up.
I've checked the diode in the power supply section, as well as the resistors which are within spec.
I've attached the schematic of the PS section, of the amp if it helps.
Thanks in advance and cheers
http://img139.imageshack.us/my.php?image=img0300os5.png
Old 10th September 2008, 11:58 AM   #2
R.I.P.
power it up with a Variac and then measure (very carefully) voltages to find where the current surge is going.
regards Andrew T.
Old 10th September 2008, 12:09 PM   #3
Hi AndrewT
Thanks for your reply mate, however I'm a newbie at this and don't have a Varaic.
This is only my second attempt at trying to diagnose & fix a tube amp, my first was only cap replacements based on visual inspection only.
This one appears to be a little more difficult.
Any other suggestion would be appreciated.
Cheers
Old 10th September 2008, 12:29 PM   #4
R.I.P.
will a tube amp with high current draw start using a high wattage light bulb tester?
regards Andrew T.
Old 10th September 2008, 12:39 PM   #5
Thanks for that. I'll have to do some research on how to rig one of these up.
Cheers
Old 10th September 2008, 12:53 PM   #6
R.I.P.
but wait till a valve/tube guy confirms if the bulb tester works to protect/slow down the start up without damaging anything.
It certainly works with SS ClassAB and ClassA amplifiers and ClassA pre-amps. But, not with soft start circuits, these have to be shorted out.
regards Andrew T.
Old 10th September 2008, 05:38 PM   #7
kevinkr's Avatar
Keep Blowing Fuses
Works fine with tube amplifiers too, and prevents catastrophic damage to the power transformer and other components in the event of a shorted cap or rectifier. Most likely to be either in this case. Something like a 100W bulb should be adequate for troubleshooting purposes to identify a failed component. Amplifier will not operate near normally with the bulb in series, a higher wattage bulb would permit that once the issue has been identified.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 10th September 2008, 06:26 PM   #8
Zibi is offline Zibi  Poland
http://www.geofex.com/ampdbug/fuseblow.htm
Old 11th September 2008, 01:17 PM   #9
Hi All
Thanks for all of the replys guys.
It's probably simple, but can anyone assist with with a scetch of how to built a tube tester and how to connect it.
I've googled, however noting of whats described was found.
Cheers
Keep Blowing FusesHide this!Advertise here!
Car Amp help? Fuses blowing... Tolo Car Audio 1 3rd December 2007 01:42 PM
Help, new PSU blowing fuses TDWesty Chip Amps 14 4th March 2007 07:29 PM
Blowing fuses balance Tubes / Valves 2 5th March 2005 02:16 AM
blowing fuses homegrown45167 Car Audio 2 22nd October 2004 12:16 PM
The Fuses Just Keep Blowing raffir Chip Amps 19 22nd June 2003 03:49 AM
