| diyAudio Sponsor | ||
hi folks !!!....i'm brand new on this site and an avid vintage hi-fi fan.......i would like to thank you all in advance for any help you can lend me !!!......i recently picked up a pair of old Quad II mono block tube amps .......a local tech and friend of mine went through them and discovered the power output transformers were no good............anyone have any ideas for suitable replacements or how i should proceed ?......thanks again !!!....regards , Ben
#2 |
If you don't need to switch output impedances you may take one from Edcor with 4 and 16 Ohm output, and use 4 and 16 Ohm taps for cathode feedback.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 | |
It seems odd that BOTH mono blocks have same transformers that are bad...?????? Are you refering to the Output Transformer or the Power Transformer??? Make sure you have the 120V version tap on your power transformers, not the 200, 220, 240 volt versions.... Chris |
#4 |
my bad ....it is the output transformers.......one puts out 5 watts and one puts out 20 watts but arc's and blows a fuse in about 45 seconds........and they are the 120 volts..........one output transformer arc's internally and one blows a fuse in 45 seconds.......i just got off the phone with my tech , he seems to think it's a bit hopeless ...rather like throwing good money after bad.........wasn't what i wanted to hear but oh well ......anyone has any other suggestions i would really appreciate it but these may end up being a doorstop and a paper weight !!......again , i really appreciate the help !!
| GU-50 100W output and power transformers | Wavebourn | Group Buys | 48 | 15th March 2011 06:34 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 11:44 AM |
| Power Transformers in Output! | mod_evil | Tubes / Valves | 17 | 25th May 2006 09:31 AM |
| Page generated in 0.07675 seconds (74.25% PHP - 25.75% MySQL) with 10 queries |
