diyAudio Sponsor
Old 9th September 2008, 10:36 PM   #1
Default Series of Diode on HT Plate
Hi to All
I have many times seen the Anodic Rectifiers Build with series of two diodes.
as this : http://www.drtube.com/schematics/laney/lc50.gif
If I use series of two 1N4007 (1000V 1A) for rectifier 1500Vac (without any resistive divider) in reverse bias, Have I 750Vac on each diode ?
I suspect that this connection doesn't guarantee the equal distribution of the potential during the reverse polarization of negative half-wave.
but this schematics run on many amplifiers... I am wrong ?
ThankYou
(sorry for my english from Italy)
Old 9th September 2008, 10:54 PM   #2
Miles Prower's Avatar
Default Re: Series of Diode on HT Plate
No you are not wrong. That isn't the right way to use silicon diodes in series. These require both equalizing resistors and capacitors for transients. Otherwise, the voltage distrubution won't be even, and may even cause poofage.
It's either a design that cut corners due to stingy pencil-pushers, or they didn't know what they were doing.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 9th September 2008, 10:55 PM   #3
Send a message via AIM to DigitalJunkie
I have seen large value resistors in parallel with the diodes before,similar to the equalizing resistors used on series'd capacitors.
Here's one example:
http://www.dogstar.dantimax.dk/tubes...cs/pwrsups.gif
Laser Diode Successor of SLD-104U for SONY ESPRIT KSS Series tiefbassuebertr Digital Source 23 28th April 2011 06:46 AM
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
rectifier diode in series with AC heating element to save energy? star882 Power Supplies 18 11th June 2007 06:46 PM
Subwoofer Plate Amplifier Base Plate supplier? jwells777 Parts 1 11th May 2003 07:40 AM
Page generated in 0.08385 seconds (69.11% PHP - 30.89% MySQL) with 10 queries
