diyAudio Sponsor
Old 8th September 2008, 10:40 PM   #1
Trout is offline Trout  United States
Trout's Avatar
Default The Return Of Blackburn Mullards?
If this is actually true,
We may be entering another new era of quality Valves
http://www.techtubevalves.com/index.php
The New ECC83 Data and Picture
It looks freaky!!
Blackburn MicroTech Solutions (BMS) has been formed from the former Philips Components organisation that itself started life as the Mullard Radio Valve Company Limited in 1938.
BMS is located on the original Mullard Valve site at Blackburn, England. Since the death of the valve for popular use following the invention of the transistor the former Mullard site has continued to develop and manufacture key components for the cathode ray tube industry. One such key component being the thermionic cathode.
With the background knowledge of valve manufacturing and cathode development, the Blackburn factory is once again able to be at the leading edge of valve development. 2008 sees the launch of the first real valve development since its initial launch back in the 1920's.
Old 8th September 2008, 11:24 PM   #2
nhuwar is offline nhuwar  United States
nhuwar's Avatar
That things kinda weird and cool looking at the same time.
Nick
Old 8th September 2008, 11:25 PM   #3
astouffer's Avatar
Wonder what it looks like when lit up? Can't wait to see a planar 300b
Old 8th September 2008, 11:26 PM   #4
athos56 is offline athos56  United States
athos56's Avatar
My two questions, how do they sound, and how much do they cost
Old 8th September 2008, 11:47 PM   #5
Trout's Avatar
I am fairly sure we will see reports popping up soon if they display actual functioning versions at the show.
Their first public showing will be at the London Sound and Vision Show 19th – 21st September, Park Inn Hotel, Heathrow.
My thoughts exactly.
I am surprised at the lack of mica supports, Maybe those beefy contacts will not rattle? Less glass contact = less microphonic problems?
Eh who knows, But if it works 10 years as stated, and it sounds good, it will be worth buying even at $75.00.
Old 8th September 2008, 11:52 PM   #6
tubelab.com's Avatar
Question, what do you do with a CRT production line now that the computer and TV display world has gone flat (literally)? Answer, you find a creative outlet for your "electron guns".
Look inside an old computer monitor or TV. I don't think that it is possible to build a CRT gun that could handle 60+ mA. The average cathode current in a 25 inch color TV is about 1/2 mA per cathode. There are 3 cathodes in a color TV. "Plate" (shadow mask) voltage is typically 25 to 27 KV!
The "guns" shown here look tiny by TV standards.
If these are realistically priced, I will be "testing" one.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 9th September 2008, 12:40 AM   #7
Default Re: The Return Of Blackburn Mullards?
It looks freaky!!
The new tubes use much different construction and materials than the old Mullard stuff. Look at the difference in interelectrode capacitance for just one example.
It looks to me like the only thing they have in common with the old days is the location of the plant.
The tubes will likely have to stand or fall on their own merit. The odds of them sounding just like the Mullards of the past are long indeed. And since volume is the key to low pricing, I doubt you'll see these at the kind of prices where you find other current production stuff.
Old 9th September 2008, 12:53 AM   #8
The CRT technology does't use wire-wound grids but solid pieces of metal , so probably the microphony isn't an issue .
Old 9th September 2008, 01:32 AM   #9
Geek's Avatar
Is that the cathode lead tied to the top? Hmmm, I'd worry about it becoming a nasty little a-k feedback coupled VHF oscillator if too much anode lead inductance get in the works.
Funky lookin' thing though. Cool!
Cheers!
Old 9th September 2008, 02:05 AM   #10
athos56's Avatar
Default hmm
They have a sales email, maybe they'll release some samples to the DIY community, it would be the fastest way to secure some early market research and generate sales if they turn out to sound good. I'm going to give them a try.
Email sent, we'll see what they say...
TechTubes - The return of Blackburn awedio Tubes / Valves 23 1st March 2010 08:14 AM
TechTube TM Blackburn status kmaier Tubes / Valves 3 10th January 2009 09:14 AM
Blackburn Mullard/Philips video nickds1 Tubes / Valves 0 15th September 2008 08:49 AM
New ST-70 Driver board from Blackburn Audio Original Burnedfingers Tubes / Valves 18 27th July 2008 01:28 PM
Mullards branded as Telefunkens??? safetyman Tubes / Valves 7 10th August 2005 03:46 AM
Page generated in 0.11057 seconds (78.89% PHP - 21.11% MySQL) with 11 queries
