| diyAudio Sponsor | ||
I have a Fisher X 101 D amp that uses 7951 output tubes. It has a bad output transformer and I'm trying to find a replacement. If someone had a broken down Fisher unit that had that kind of transformer and wanted to sell for parts I'd be interested.
#2 |
You might list the part number, since it might have been used in other Fisher models as well.
#3 |
we all have problems only some people have more than most.... long live the Magyar (Hungarians) in the world! |
#4 | |
If it can't be fixed qwad's way, I'd suggest Heyboer in Michigan. I'd disagree on the big bux worry, as I've gotten very good prices from them on modified Peerless outputs. S265Q and S271S for starters. Less than a C-note on the S265Q for instance... cheers, Douglas
the Tnuctipun will return |
#5 |
Malcom,
The other posters have given you some good options. Yet another option is to buy a pair of trafos from Edcor and sell the good OEM trafo off. Edcor's model CXPP60-MS-6.6K looks like it will do the job. Being able to experiment with ultralinear mode "finals" is an option you would gain, if you buy Edcor "iron".
Eli D. |
#6 |
Can you provide a part #? I have a apir of OPTs that might be what you are looking for.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Thanks for the good suggestions.
I'll track down the part # for transformer. I actually have a service manual for amp. But the place it was kept in the past had mice and a mouse chewed through the one spot that had the numbers for transformers. But I found a place on the web that has photocopy of manual so might take a little while to receive snail mail. |
#8 |
Fisher generally stamped the part number and manufacturer / date code into the transformer end bell.
#9 |
Yes indeed there were two numbers on the bell. The first was T991-116-3C. The second was 9294431. I assume the first was the part number.
#10 |
The Fisher 800C uses the same transformer number but with -1 and -2 at the end. I think the only difference is lead length. The 500C may be the same as well - I may have the service manual at home, I'll check. So perhaps you can spread your net a bit wider...
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 06:10 PM |
| Fisher 400 Output Transformers | wrenchone | Tubes / Valves | 6 | 7th November 2008 04:52 AM |
| main power transformer for Fisher | SharpyWarpy | Parts | 4 | 2nd July 2007 10:53 PM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 07:15 PM |
| "The Fisher" tube amp 7189 output tubes | laflamme | Tubes / Valves | 4 | 28th August 2004 01:40 AM |
| Page generated in 0.11645 seconds (80.56% PHP - 19.44% MySQL) with 10 queries |
