| diyAudio Sponsor | ||
#11 |
OT is little bit.
Does anyone know any resource that provide the Fisher transformers specifications? Thanks!!
- Fred - |
#12 |
Wish I knew of one - guess I'll have to create the database myself. Please send your Fisher transformers to me for measurement. At least two each for a representative sample...
Actually I have an 800C and a 51 mono amp, transformers from a 500B, a friend has transformers from 70A, 400, and a few others. And I have at least the Sams folders for a few more... so I can start the project but will need others' input to fill in a LOT of blanks... |
#13 |
Hi Tom,
I have a X-100-3 which is in very good shape, almost all stock. I also have a 400 which has a chassis that is in need of no less than a can of Never Dull polish .... Since I don't use the tuner, I am thinking about reuse the irons to build an amp from a different chassis. If so, I am wondering what kind of tubes can I use rather than the 7868. I suppose all Fisher design that uses 7591 should work with these transformer. I am hoping that there will be more option if I know the iron's specs. Thanks,
- Fred - |
#14 |
I had good luck finding a power tranny for my Fisher 101-B. I saved a search in Ebay with Fisher 101 transformer and in days ebay sent me mail with a tranny from a 101c, which is slightly larger, but it works fine for years and voltages ok. I got it for only $10 and it saved a great amp. Try saved search
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 06:10 PM |
| Fisher 400 Output Transformers | wrenchone | Tubes / Valves | 6 | 7th November 2008 04:52 AM |
| main power transformer for Fisher | SharpyWarpy | Parts | 4 | 2nd July 2007 10:53 PM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 07:15 PM |
| "The Fisher" tube amp 7189 output tubes | laflamme | Tubes / Valves | 4 | 28th August 2004 01:40 AM |
| Page generated in 0.07224 seconds (73.33% PHP - 26.67% MySQL) with 10 queries |
