| diyAudio Sponsor | ||
EF86 as a volume pot, line pre 2008
read me Hello, you can find schematics and additional information in the blogs. Use a web site translator to translate the text to your preferred language. Signal schematic Power supply schematic Kind regards, Darius |
#2 |
What's the range ( dB) of your volume pot ? I can't find it in your blog . Thank you !
#3 | |
#4 |
Very interesting concept, thank you for sharing. If I may ask a few questions:
How does it sound, did you compare it to other preamps that you built and how do you rate it compared to those topologies. How good is channel balance with your design (assuming you had exactly the same control voltages for both channels)? Btw. I presume you could use a single mono pot to create the control voltage? Thanks in advance.
Martin Rupp |
#5 |
Try 6BA6
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#6 | |
website translator |
#7 |
Hello MRupp
I am happy with the sound after "tube rolling". You have to find quiet ECC82 Gyrator triodes and well matched EF86 to get a good channel balance. A volume pot is definitely the easier way, but I wanted a tube solution. I am going to add a simple cable remote control (poti in a box)* This makes sense to me. Kind regards, Darius *500KA switch able in series to R11c |
| volume pot in balanced line | Bouatila | Instruments and Amps | 4 | 5th November 2008 05:54 PM |
| Master Volume pot on Ballanced Line. | Raphael Shaw | Parts | 4 | 15th September 2006 08:42 AM |
| Line level volume control | rs1026 | Chip Amps | 9 | 22nd May 2005 06:18 PM |
| Cabinet Volume for Line Array | ralph-bway | Multi-Way | 2 | 29th July 2004 09:50 PM |
| volume control and line out questions | roofingboom | Solid State | 1 | 22nd May 2004 11:23 AM |
| Page generated in 0.09143 seconds (74.15% PHP - 25.85% MySQL) with 10 queries |
