| diyAudio Sponsor | ||
Hello everybody
I wanted to know : Does a set amp prefer a 8 ohm (constant) driver or a driver which impedance go between 8 and 16 ohm ? (or between 6 and 16 Ohm) but mostly around 12 or 14 ohms Thanx |
#2 | |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 | |
look : ![]() So as my drivers are 16 ohm (well it doesn't mean anything i know) will it work better on set as set loves 16 Ohms |
#4 | |
#5 |
A set prefer a 16 Ohm than a 2 Ohm no ? |
#6 |
Maybe you should back up and give us a bigger picture as to what you are thinking or planning to do?
#7 |
No need to understand the whole system
--- It is just a theorical question what will give better result for the bass with a 5W set amp : - a driver constant at 8 Ohm -a driver that oscillate between 6 and 16 Ohm |
| What impedance? | jaya000 | Multi-Way | 11 | 21st November 2008 07:04 AM |
| LM386-4 impedance stability/safety | JonnySwitchblade | Chip Amps | 0 | 23rd February 2008 10:36 PM |
| Hi Vi SD1.1 impedance | guitarded | Multi-Way | 0 | 3rd February 2008 08:35 AM |
| Need help understanding transformer impedance ratios and impedance matching | percy | Tubes / Valves | 5 | 28th February 2005 08:35 PM |
| impedance | Reed | Multi-Way | 10 | 29th November 2004 11:40 AM |
| Page generated in 0.08142 seconds (84.09% PHP - 15.91% MySQL) with 10 queries |
