| diyAudio Sponsor | ||
diyAudio Moderator Emeritus
Apparently one of the shortcomings of say a LM317 or even a LT1086 as current or voltage regulator is that they essentially do little attenuation above 1k.
So 50/60Hz is dealt with effectively but that is about it....in terms of a filament supply. Matthijs de Vries's solution (MachMat.com) is to use a fet. This got me thinking. Could I simply make a current source with say an IRFP240 and have something with much higher impedance so that a lot more rubbish above 1kHz is attenuated? Or is the problem with such a device that it needs a higher voltage across it to work? A typical application I would want to use it for is say the filemant of a 300B. |
#2 |
работник
I have bored everyone to death about how much you can improve over LT1086 or any 3-leg regulator.
current source featuring short feedback loop is needed together with a gyrator on the other filament terminal. Here is the original design, still going strong. It has been built by other folks on the forum, and found to be a real improvement - New DHT heater You can experiment with a FET in either the gyrator ( may work well) or the current source (you'll need a high performance scope to check you're not oscillating at 1 to 50MHz) but I prefer BJT here. You can easily check when your 300B filament design is working well - just do a quick comparison to ac-heating. If it is not better in every way you can imagine - you need to keep working on it! |
#3 |
Thanks Rod,
I remember that one. I was just too afraid to build something that complex. Regards, Bas |
#4 | |
I ended up buying Guido's kit, because I didn't have room for more transformers and because it has a low enough drop out to use the regular AC filament winding. If you are starting a new amp, these issues may not be present. Sheldon |
#5 | ||
I'm still thinking about my original question. After all a DN2540 n-channel mosfet makes a pretty good CCS. Take something similar but one that can handle the current...and voila? A filament CCS with a very high impedance? Quote:
So I was thinking that when I've got some time to re-draw the thing so that it would become evident( to me) how to wire it up. |
#6 | |
работник
But some things really should be observed: - don't share the trafo winding with the other channel or connect anything to ground - or the 300B cathode circuit will be shorted; - use schottky diodes for the bridge/FW rectifier; - good elko caps in the supply please! Panasonic FC or Nichicon low impedance - they are cheap, after all. You can compare the sound with ac-heat to see how well you are doing. |
#7 | |
работник
Using the Drain as a current source is superior to the source circuit, since the source transitions into a LOW impedance node for frequencies outside the control loop's response. The drain is high impedance for all frequencies, other than spoiling effects of parasitic capacitance. Remember to allow enough volts across the FET to prevent unwanted capacitance effects (2-3V should do.. I couldn't find a data sheet for it tho) FETs make good gyrators too, but N-channel enhancement type are best (IRF740s are in many a DIYer's toy box). Try 1M gate resistor and 470nF film cap to V-). Remember to use an insulating pad/shouldered washer to attach each FET to a big piece of chassis or heatsink. |
#8 | |
Sheldon |
#9 | |
#10 |
работник
The IRFP240 can be used, but unlike the DN2450, it is an enhancement mode type - so you can't just use it as a current source by adding a resistor in the source circuit (like you can with Depletion-mode FETs).
you could build it into my circuit using the extra transistor to control the current - but it will be inferior to the ordinary transistor in that position, mainly due to much higher capacitance. FETs are often harder to tame for oscillation, too. Look out for some nice 2SC4381 NPNs or equivalent sometime. These can heat a 300B with 3V across them, using only 100x100mm aluminium 2mm thick for a heatsink. Best of all they have tiny parasitic capacitance - about 1/10 of the FET. http://www.cricklewoodelectronics.co...tion=0&page=16 |
| One 300B filament supply for stereo? | dshortt9 | Tubes / Valves | 1 | 7th September 2007 08:14 PM |
| Do I really need voltage regulation on such a small current? | Sunsun22 | Power Supplies | 9 | 13th October 2006 08:23 PM |
| 300B Filament Voltage Range | dsavitsk | Tubes / Valves | 4 | 14th October 2005 07:07 PM |
| 300b filament q, yes another one. | gtmcgar1 | Tubes / Valves | 7 | 12th July 2005 08:31 AM |
| Minimum filament voltage for 300B | kusojiji | Tubes / Valves | 32 | 6th July 2005 12:34 PM |
| Page generated in 0.12700 seconds (83.84% PHP - 16.16% MySQL) with 10 queries |
