diyAudio Sponsor
Old 1st September 2008, 01:29 PM   #1
Default Help for choke input regulated PSU
HI , ( sorry for my english)
Suppose I have a linestage 6922 wit 200 Volt series regulated (
with a mosfet type). The storage cap is about 1000mF. End.
Now I want modding into a LC input type (after the regulator).
Does I have to erase the cap and soubstitute wit L?
perdone for my horrible exposition, I am totally rookie on electronic
Paolo
Old 1st September 2008, 04:24 PM   #2
DougL is online now DougL  United States
Download Duncan Amps PSUD
Some basics: The voltage after the first choke / Cap will be about .9 of the Transformer. Cap input PS give about 1.4 times the Transformer.
It is also important to get the Q of the Choke input less than 1. About .5 is optimum R = (1/Q) * Sqr(L/C) this equation calculates the required resistance of the choke. You can add an additional resistor.
Also, you need to insure that the choke meets min and max current for correct operation. While PSUD is probably definitive, here are the equations.
Imin = Vrms / L
Imax = Idc + Iac where Iac = 1350/L for 60 Hz and about 1100/L for 50 hz
You may need a higher voltage transformer.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 1st September 2008, 04:35 PM   #3
Sheldon is offline Sheldon  United States
A picture is worth a thousand words. Show us a schematic of the power supply. What do you hope to gain by making the proposed changes?
Until then, I don't see the purpose of placing a choke after a regulator.
Sheldon
Old 1st September 2008, 05:19 PM   #4
Thanks guys,
Doug, time to study your formulas
Sheldon,
because I like the Thoersten Loesch approch. I think you all know him.
The toccata MK1 preamplifier has a PSU that have intrigued me.
I think To skip the first choke and rest is quite similar to my "idea".
The regulator is approx. the same .
I'm perplexed by the low value of the choke. Only 10H. But for this
maybe I can ask the author.
Thanks for your comment
Paolo
Old 1st September 2008, 06:45 PM   #5
Do yourself a favor. Ask PSUD first. Thoersten Loesch has stopped posting on the hobbyist sites, because of very understandable professional commitments. Ask here first.
In order to communicate better, a rough drawing of your idea would be very helpful. Also a link to the schematic of the " toccata MK1 preamplifier" would be helpful.
My advice is to either understand before you build, or build per the schematic, then modify.
Doug
Old 1st September 2008, 07:05 PM   #6
Doug You are right, my mistake.
Unfortunately electronic is sort of chinese language for me
below is the schematic of the Toccata mk1
Link
thanks
Paolo
Choke regulated power supply for S/S amp Matt Rowland Solid State 31 22nd March 2009 01:58 PM
Choke loaded PSU versus VR tube regulated PSU? G Tubes / Valves 37 20th March 2008 10:45 PM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
choke regulated power supply Ap Tubes / Valves 20 12th November 2003 02:08 PM
Page generated in 0.09142 seconds (74.92% PHP - 25.08% MySQL) with 10 queries
