| diyAudio Sponsor | ||
I would like to build an headphone amplifier. The concept that i have made up is: OTL, Ultra Fast Diode Rectifier, Relatively low voltage, One Tube channel. What tube would you suggest i use?
And mind that the output impedance must be 50 or below!
Stefan Jordanoff |
#2 |
I was thinking 6S45P
Stefan Jordanoff |
#3 |
Yours headfones - low impedance /30 - 60 ohm/ or higt /200-300-500 ohm/?? It's very important!!!
#4 |
Nikola, 55Ohms.
Stefan Jordanoff |
#5 |
#6 |
You can try 6as7. Its a nice tube for headphone amp too
#7 |
6H30C - /Russia/ lake pre-amp, and 6H13C/Russia/ lake output
kathod. |
#8 |
6S45 = 6C45 ?
Simple 6C45 power amp here: http://www.paeng-design.com/devices_frame.htm (in section: High ó tubes, Part 111) Adapt to headphone by changing transformer ratio? 6C45 datasheet suggests limited input swing / bias, so will need attenuator at input if using 2V output from CD player. Anecdotal evidence suggests 6C45 oscillates easily, so use well regulated supply and grid stopper resistors. More info here: http://www.vt52.com/info/measure/6s45/6s45.html ...and also in projects section of the site. Good luck. : ) |
#9 |
I don't think you wil be able to power 55 ohm headphones with a single tube OTL. You will need push-pull with feedback to be output transformerless. Or you could use a solid state buffer with a single tube gain stage.
#10 |
I try to escape from SS. Eventually only SS rectifier. I gues what i want i can't find. My new idea is a OTL with 6S19P as output tube, and 6N23P or 6N24P as input tube. Can someone give me a scheme of such an amp?
Stefan Jordanoff |
| FS tube tuner, Active filter kit, tube amp, amp3 | Josephjcole | Swap Meet | 9 | 20th July 2007 04:05 PM |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 03:09 AM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 01:19 AM |
| tube driving the same tube - whats the collective word? | zobsky | Tubes / Valves | 3 | 13th June 2005 06:47 AM |
| Page generated in 0.13789 seconds (78.53% PHP - 21.47% MySQL) with 10 queries |
