6S45 = 6C45 ?
Simple 6C45 power amp here:
http://www.paeng-design.com/devices_frame.htm
(in section: High ó tubes, Part 111)
Adapt to headphone by changing transformer ratio?
6C45 datasheet suggests limited input swing / bias, so will need attenuator at input if using 2V output from CD player.
Anecdotal evidence suggests 6C45 oscillates easily, so use well regulated supply and grid stopper resistors.
More info here:
http://www.vt52.com/info/measure/6s45/6s45.html
...and also in projects section of the site.
Good luck. : )
More info here:
Good luck. : )
- Tubes / Valves
- What tube to use.
