diyAudio Sponsor
Old 8th September 2008, 07:13 AM   #31
Elias is offline Elias  Finland
Elias's Avatar
The compensation current seems to be quite critical. Here's the response at -5%. Again at 20Hz.
Reinventing the wheel !
Free wavelet software for audio analysis click here!
Old 8th September 2008, 07:14 AM   #32
Elias's Avatar
And the same at +5%:
Old 8th September 2008, 07:16 AM   #33
Elias's Avatar
At 80Hz saturation seems to be reduced a bit, but still visible. Here's response without compensation at 0.5W 80Hz:
Old 8th September 2008, 07:20 AM   #34
Elias's Avatar
And 80Hz with compensation. Not only amplitude but also phase is corrected!
Using DC compensation freq response is much improved. Without compensation -3dB is at 80Hz. With compensation freq response is 0dB at 20Hz and -1.6dB at 20kHz. Cannot test lower than 20Hz with my signal generator, but it seems to go really low.
Overall quite promising results
- Elias
Old 8th September 2008, 07:28 AM   #35
Hi Elias
Very interesting that you put your ideas to practice!
May I ask what method you used for DC compensation?
Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 8th September 2008, 08:34 AM   #36
Elias's Avatar
Hello Erik,
The compensation is very simple. I feed DC current from voltage source of about 270mA to the 43V secondary through 100ohm resistor. I know it loads the primary a bit, better would be using current generator with high impedance. That would be one of the next steps I'm planning to do. However, the impedance level propably is not a big issue.
- Elias
Old 8th September 2008, 10:54 PM   #37
jerluwoo's Avatar
Have you tried simply grounding the cathode through the secondary so that you have the same amount of dc through primary and secondary? Curious if this would have a cancelling effect on saturation or not.
Old 8th September 2008, 11:02 PM   #38
Hi Elias
I don't think transformers like to be treated the way you supposed. If you are going to the trouble of adding a compensating DC current, why not operate two valves in Class A push-pull?
The problem is that the offset current does nothing for the signal, but adding another valve on the other primary winding would make use of that winding, give you twice the power, and reduce the DC all in one go.
cheers
John
Old 8th September 2008, 11:02 PM   #39
316a is offline 316a  England
316a's Avatar
- Elias
Well done ! Are you going to share the design ? I'm surprised at your upper rolloff . I got -0.5dB down at 20khz using a 6B4G into a 230:9+9 Talema 30VA unit .
cheers
316A
Old 9th September 2008, 05:20 AM   #40
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Probably due to the size of the Tx
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
No mains transformer B+ ? Salas Tubes / Valves 9 14th March 2007 12:04 PM
Question on Mains Transformer MlinarS Tubes / Valves 1 1st March 2005 12:57 PM
Mains Transformer Question reticent67 Parts 14 6th September 2004 12:54 PM
Quad II mains transformer 405man Swap Meet 1 19th January 2004 06:49 PM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 05:36 AM
Page generated in 0.10597 seconds (85.63% PHP - 14.37% MySQL) with 11 queries
