diyAudio Sponsor
Old 10th October 2008, 07:07 PM   #171
boiss is offline boiss  Italy
Hi Revintage,
Some food for thought, really not too worried about the driver as it will be constantly running grid current. Driver could even be SS transformer coupled. I want 2 big bottles up there, fantastic visual impact and with 150 watts of filament power at least 10W of impeccable sound.
A bit miffed that it cant be done with 100V HT. Anyone understand why 833 characteristics look like a classic pentode?
Seriously, triode chars are all vertical while these are all horizontal.
Mike.
Old 10th October 2008, 07:13 PM   #172
Maybe I should add that I use 813s where others use a DL96, ie even lower HT like 25V for RF etc.
Mike.
How about a simple desktop regen MW RX (tuner) using an 833 with all of it running on 10V dc inc the filament supply.
Mike.
Old 10th October 2008, 07:24 PM   #173
Just an example, A modulator for 1930s radios on Medium wave
813 screen modulated, HT for both valves 25V, O/P 1mW at 1MHz into 50ohms harmonics <-60dBm.
Old 10th October 2008, 10:30 PM   #174
revintage's Avatar
Will use EL519/6KG6 instead of 6550 as anti-triode in my SEPTORS with parallelled 6B4Gs. Sims so much better, must be the high Gm. Will take some photos tomorrow when I have mounted the magnoval sockets and topcaps.
Brgds
Lars
Old 13th October 2008, 07:25 PM   #175
hoktuna is offline hoktuna  Sweden
Yesterday i move the 150H choke and hook up the scope.
The sine wave now looking good below 100 hz
Old 3rd November 2009, 09:36 PM   #176
Elias is offline Elias  Finland
Elias's Avatar
Hello,
Time to move this thread forwards!
This idea came to my mind of output toroid current compensation. For the input signal it acts like a SE amp. It works with split supply. Capacitor decouples the signal at the middle. No need for transistor current mirrors No need for current tracking, same current goes through both windings. I think some of those 115V + 115V mains toroids works fine here as in my previous protos as well.
What do you think?
- Elias
Reinventing the wheel !
Free wavelet software for audio analysis click here!
No mains transformer B+ ? Salas Tubes / Valves 9 14th March 2007 12:04 PM
Question on Mains Transformer MlinarS Tubes / Valves 1 1st March 2005 12:57 PM
Mains Transformer Question reticent67 Parts 14 6th September 2004 12:54 PM
Quad II mains transformer 405man Swap Meet 1 19th January 2004 06:49 PM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 05:36 AM
Page generated in 0.09074 seconds (74.52% PHP - 25.48% MySQL) with 11 queries
