diyAudio Sponsor
Old 7th October 2008, 02:41 AM   #151
I run the description through my head backwards and sideways,
the lightbulb inside must be missing the pullchain or something.
I know I'm going to regret this, but could you draw it?
Old 7th October 2008, 03:31 AM   #152
smoking-amp's Avatar
"could you draw it?"
No problemo. Seems an obvious solution to me, someone may have already mentioned something similar. I think Anatloyi (Wavebourn) mentioned such a self regulating CCS for something.
The two drive signals are scaled so that the tail voltage AC variation is nulled to a minimum.
Ohms Law V = I R
Old 7th October 2008, 03:47 AM   #153
CFB version. The drive signals can be adjusted for a minimum AC null on the tail again. Or maybe just leave Q1 with a steady bias on its gate, could be good enough. Just trying to keep audio out of the CCS tail's slow regulation (no resonance then). The slow regulation is for compensating non-linearity in the tube, causing growth of current on large signal bursts.
Since the audio doesn't go thru the cap, the RC low pass can be set to be lower than the L (OT primary) and C resonance, avoiding resonant activation by enveloping, I think.
Ohms Law V = I R
Old 7th October 2008, 04:14 AM   #154
And now for something completely different:
Anyone remember what engineer this this crossed
bias balance was named for? I've seen it mentioned
here before, recently too, I'm sure of it... But I draw
a blank what name to search for...
Maybe those bypass caps at the bottom should have
been moved up and used as coupling caps from grid
stoppers to the driver(s) instead... My bad.
Old 7th October 2008, 04:20 AM   #155
Michael Koster's Avatar
Ding!
It's Alan Dowter Blumlein, Ken
Old 7th October 2008, 04:21 AM   #156
Alan Blumlein
how many bonus points do I get?
edit:
Darn, Michael beat me to it!
Looks like the AC signal will be going thru that cross coupling cap though. Resonance?
Ohms Law V = I R
Old 7th October 2008, 04:45 AM   #157
Serious bypass goofup fixed...
As for a resonance? I suppose it probably has one...
I don't see any reason it would be within the audio
passband. Does it cause DC balance to oscillate?
Would that mode ever have a gain approaching 1?
Are you suggesting its a motorboat of some sort?
Old 7th October 2008, 04:50 AM   #158
How about just getting rid of the transformer altogether. More problems than its worth. Now we get a SET emulation without triode or transformer. Probably works better than SET. Q2 would be a constant Beta part. Uses complementary current outputs. Maybe needs some extra resistance in the Q1 source lead.
Ohms Law V = I R
Old 7th October 2008, 05:00 AM   #159
Fixed
On the Blumlein scheme, I wouldn't think it would be any more problem than parafeed. Just have to be careful where the resonance falls so it doesn't get excited. Can probably make it a damped resonance as well. But if it can be gotten rid of ..... one less artifact.
Ohms Law V = I R
Old 7th October 2008, 05:12 AM   #160
Yeah, that works. The screen sees RL, and damn what the plate sees.
Within a pentode, plate don't much affect audio processing decisions.
Its kind of odd the screen can pull both up and down, is there some
screwball variant of the anti-triode at work in the output totem?
No mains transformer B+ ? Salas Tubes / Valves 9 14th March 2007 11:04 AM
Question on Mains Transformer MlinarS Tubes / Valves 1 1st March 2005 11:57 AM
Mains Transformer Question reticent67 Parts 14 6th September 2004 11:54 AM
Quad II mains transformer 405man Swap Meet 1 19th January 2004 05:49 PM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.11778 seconds (70.89% PHP - 29.11% MySQL) with 11 queries
