| diyAudio Sponsor | ||
#121 |
Goooooodmorning amerika
One channel of "the prototype"is upp and playing sweeeet music. The other channel need some tweeking,it is distorted(right word?) Maybe core satur,weŽl se tomorrow. |
#122 | |
Hello and Good evening!
If the problem is core saturation, this thread is the right place to get that solved! ![]() - Elias |
#123 |
This is the proto hoktuna built, but with 6P3S instead of 6V6. We discussed over the phone and came to the conclusion that the second channel probably had a faulty 6P3S or a leaking coupling cap. If not so, it could also be a self-oscillating 6C45.
We are looking forward to both channels working, to evaluate the amp soundwise.
Brgds Lars |
#124 |
Hello,
My second proto of current compensated toroidal SE amp is coming! Next thing to do is to wire it up. In the pic background can see the output toroid. I wound some extra turns to have more variety of impedances. - Elias |
#125 |
Both channels of hoktunas proto is now up and running. Plays with authority, good bottom and very good depth of image through a pair of 87dB sensitivity speakers
C1 is 100u between the tubes cathodes, 6V6 is a 6P3Sand 6C45 is choke-loaded though.
Brgds Lars |
#126 |
Next thing will be too hook the amp on my main speakers.
Onken 360L whith Altec 416 8A Homebrewed Altec multiell with JBL 2441.http://i194.photobucket.com/albums/z...a/DSC04462.jpg |
#127 |
Here is the amp with ps.
http://i194.photobucket.com/albums/z...a/DSC07103.jpg |
#128 |
Congratulations Hoktuna and Lars!
You have a working push-pull signal-mirrored amplifier. The bypassed current mirror may be a very good solution to DC balance and AC drive. I look forward to some measurements. It looks like you're working into about 11K anode-anode based on the transformer ratio. What's your output at OPT saturation? Also, a great use of a pentode, pushing current around under the control of a DHT. I have a pair of 414s, I'm thinking about baby Onkens and 511 horns. What drivers do you use? Cheers, Michael |
#129 |
Actually the impedance ratio is 9000:8.
One must measure the unloaded secondary to determine voltage ratio and for this Autema 30VA it is 230:6,8V. A 230:9V unwound to 8,4V unloaded would be perfect...... Anyway we will soon measure and listen more. Michael, I used 414 Onkens earlier together with 511/802s and 077. Now the 511 are being rebuilt to take a 2" driver. http://www.revintage.se/narbak.JPG http://www.revintage.se/frontred.JPG Hoktunas DIY-multicells with 2441(!) and Onken 416 http://img385.imageshack.us/img385/435/multicellfr8.jpg
Brgds Lars |
#130 |
That tower looks like an open baffle. If you have
experience with 414s in OBs I'd be very interested indeed, because I have a Heil AMT I'd like to pair up with a dipole mid. Conventional wisdom is the 414s too low Qt for OB but what if I use it as a mid down to 100-120 Hz and make my sub go up to that? Also that octagon tube looks like an interesting sub. I'm also working on a tube sub design. I guess there is speaker design forum... Can't wait to hear more about the SETOR. Cheers, Michael |
| No mains transformer B+ ? | Salas | Tubes / Valves | 9 | 14th March 2007 12:04 PM |
| Question on Mains Transformer | MlinarS | Tubes / Valves | 1 | 1st March 2005 12:57 PM |
| Mains Transformer Question | reticent67 | Parts | 14 | 6th September 2004 12:54 PM |
| Quad II mains transformer | 405man | Swap Meet | 1 | 19th January 2004 06:49 PM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 05:36 AM |
| Page generated in 0.13196 seconds (80.76% PHP - 19.24% MySQL) with 11 queries |
