| diyAudio Sponsor | ||
I've been searching through guitar amp schematics to see if there is a simple technique for channel switching by footswitch.
For opamp based amps, there is a simple method of ungrounding the feedback network of a stage to silence that same opamp stage. This lends to a very easy to implement footswitch requiring only one contact and no relays or other devices. I was looking through commercial tube guitar amp schematics but could find no equivalent trick, all I could find were relay based channel switching by footswitches. Any ideas?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#2 |
Anybody? Bueller...Bueller...
How about ungrounding the cathode bias network? Is this OK if the grid and anode remain terminated?
#3 |
There are several issues to contend with: tube impedance, how much signal is bled through, and sending audio through the cable to the switch.
Relays solve a lot of problems and allow channel switching without "tricks", which is why they are used. The Super Twin Reverb did use a foot switch to change the bias point of a preamp tube to move it into distortion. Unfortunately, most people did not like the tone. |
| Channel Switching | AmpBuilder225 | Tubes / Valves | 19 | 1st April 2009 07:21 PM |
| Input switching gainclone, layout, general technique | Sparky OR | Chip Amps | 6 | 19th January 2009 01:37 PM |
| DIY amp channel switching | AmpKiller66 | Instruments and Amps | 5 | 3rd August 2007 03:19 AM |
| Page generated in 0.08384 seconds (75.39% PHP - 24.61% MySQL) with 10 queries |
