diyAudio Sponsor
Old 29th August 2008, 03:16 PM   #1
Cassiel is offline Cassiel  Greenland
Cassiel's Avatar
Default Pentode sounds great
Hi, i have built a little amp with the ecl86.
My surprise is that it sounded better in pentode mode. Triode had a good tone (doesn't always) but the sound was a little opaque and too much laid off for my taste.
Try this with any pentode, el84 anyone?
Only requirement is no bypass caps,input and output stage, and a higher than normal primary impedance - 10.000 Ohms or maybe more if you can.
Lovely sound, clear and natural.
Old 29th August 2008, 04:35 PM   #2
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
George (tubelab) did. He seemed happy with the result.
I've had good luck with other Pentodes as well.
Old 29th August 2008, 04:38 PM   #3
Boris_The_Blade's Avatar
Sometimes those extra two connections scare people, but there's nothing wrong with pentodes!
Old 29th August 2008, 08:51 PM   #4
diyAudio Moderator Emeritus
ray_moth's Avatar
Stalker, did you use negative feedback (other than unbypassed cathode resistors)? It's common to use it to improve pentode harmonics and damping factor.
Old 30th August 2008, 01:14 PM   #5
Cassiel's Avatar
No Ray, only current feedback...but when i get used to the sound i'll try
a voltage feedback loop too. Thought i suspect i'll get an even cleaner sound but with less air and openness.
Old 30th August 2008, 10:16 PM   #6
aletheian's Avatar
You are not alone, I tend to like the sound of pentodes too--more bite and a more aggressive response typically-- but since I listen to heavier music it makes sense for me. They just seem so unpopular that I have never bothered posting about it.
Heghlu'meH QaQ jajvam!
Old 30th August 2008, 11:21 PM   #7
ray_moth's Avatar
Well, aletheian, I'll join you as a pentode fan.
My attraction to pentodes started over 40 years ago and hasn't abated yet. Expressions like pentode authority and pentode slam get the old pulses racing. Of course, I know that triode sound is 'purer', but where's the fun in that?
Old 31st August 2008, 03:05 AM   #8
JandG is offline JandG  United States
I too am getting a high respect for Pentodes in SE as that is all the OT;s I have are SE, but in the last month or so I have ripped though many, many Pentodes & many sound excellent in the normal mode. Now I am off to learn NFB ways, I see there is many, many differnat ways to do it.I tried sceen dive this mourning on a 807 & couldn't get it to work, another day for that G2 drive thing. I like building sperate PS's & Pentodes in that mode give me a good reason to do g2 supplies & experiments. my top dog amp is a DIY PP 6l6 jobber from a very talented fella that used a Fisher 200 OT & adjustable NFB, it is a stunning sounding amp. Yep I like em..
Old 31st August 2008, 06:27 AM   #9
What is better ? Pure, real sound .....or fun ?
/6C41C - 1/2 of 6C33C -.... sounds like pentod...compromise?/.
Old 31st August 2008, 07:29 AM   #10
ray_moth's Avatar
I'm going to respond with the dreaded words "it depends", in this case on your reason for being in this hobby of ours. Good triode sound is well within reach for most people, whereas good pentode sound is more of a challenge (but also more rewarding when you get it right).
Maybe the best approach is to build a nice triode amp and keep it for listening, then build a pentode amp to use for experimenting.
Radio Sounds Great, CDs Sound Terrible sdclc126 Car Audio 5 3rd August 2007 01:22 PM
FS Gainclone Great Chassis, Potted toroidal, great sound PHilgeman Swap Meet 4 2nd May 2006 01:20 PM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 05:16 AM
sounds great, thanks to everyone that helped. Richie V6 Chip Amps 6 1st January 2005 03:06 PM
Page generated in 0.09192 seconds (86.55% PHP - 13.45% MySQL) with 10 queries
