diyAudio Sponsor
Old 29th August 2008, 03:06 PM   #1
Cassiel is offline Cassiel  Greenland
Cassiel's Avatar
Default Shindo claret
I have built only the line stage and sounds pretty good, however i do have a little bit of noise. The heaters are floating, i would like to ground one side( AC fed) but i don't know if i will surpass the heater- cathode voltage for the 5965.
Do i need to elevate the heaters above ground?
Thanks.
http://www.fortunecity.com/rivendell...et/Claret.html
Shindo schematics? frankmalz Tubes / Valves 30 1st November 2010 12:39 PM
Shindo Claret Audio_D Tubes / Valves 13 19th June 2009 04:42 PM
EMT 297 or 309 new produktion vs. Shindo Meursault Dr. ODD Analogue Source 2 25th March 2008 05:56 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Page generated in 0.06450 seconds (68.98% PHP - 31.02% MySQL) with 10 queries
