| diyAudio Sponsor | ||
What is the phase of an output taken from the plate of a grounded cathode? Is it inverting or normal polarity ?
#2 |
Inverting.
As a signal goes positive, the grid goes more positive (less negative) with respect to the cathode. So the tube conducts more. If the tube is conducting more, it draws more current, the plate resistor drops more, and the plate voltage goes more negative (less positive). hth
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
The more I go faster, the less I go slower
And vice et versa. Yves. |
| 300B Cathode Feedback + Cathode Bias | korneluk | Tubes / Valves | 13 | 7th January 2009 08:07 PM |
| UL to triode mode conversion on cathode bias amp-different cathode resistors needed? | bigwill | Tubes / Valves | 6 | 30th December 2007 12:37 AM |
| ECC83 cathode grounded = awesome overdrive (?!?!?) | voivodata | Tubes / Valves | 9 | 13th March 2007 09:36 PM |
| Any common cathode (grounded grid) schematics? | leadbelly | Tubes / Valves | 2 | 24th February 2006 07:29 AM |
| Cathode-coupled Phase Splitter Formula | MelB | Tubes / Valves | 5 | 14th February 2005 08:51 PM |
| Page generated in 0.06341 seconds (77.26% PHP - 22.74% MySQL) with 10 queries |
