diyAudio Sponsor
Old 27th August 2008, 07:35 AM   #1
sunrise's Avatar
Send a message via ICQ to sunrise
Default parallel SE 2A3
I plan to use 2 Sovtek 2A3 tubes in parallel for the power amplifier i want to build.....i am starting from ground zero...
I have found few schematics but still i am looking for more ideas ...
I would be very gratefull if somebody can suggest me some more designs that are really really good... not needed to be cheap - the only goal is to be really good design that sound good.....
thanks a lot for any help...
so parellel SE 2A3 design needed
when you burn it - burn it good
Old 27th August 2008, 12:43 PM   #2
Hi Sunrise,
http://www.audiodesignguide.com/New2A3/new2A3.html
my prefered, only one penthode driver stage, schematic down the page.
or this with more iron
http://www.audiodesignguide.com/my/pse3.html.
Philippe
Old 27th August 2008, 01:23 PM   #3
sunrise's Avatar
thnx.....
nice projects....
anybody else have some other ideas - everything that is very very good is welcome..
Old 27th August 2008, 08:44 PM   #4
sunrise's Avatar
hmmmm - not a lot of responses unforunatelly.....
at least this - for parallel 2a3 SE - how many stages??.....2 or 3.... first one to be grounded cathode and the second one cathode follower ... or maybe something like SJS Arcadia amplifier
http://www.users.globalnet.co.uk/~va...es/ARCADIA.GIF
it seems to me that in Arcadia we have a lot more gain than needed for integrated amplifier - but probably i am wrong....not sure....
or maybe something like AN Neiro - there we have SRPP at the input and 5687 as a cathode follower (two 5687 triodes in parallel)....?!
one electron has an interesting project with three 2A3 in parallel....well, i need two in parallel - this might work with two of them right??!
anybody has some comments related 6BL7 tube used in this project....?
http://www.one-electron.com/SEA1_p3.pdf
maybe a loftin white with 12AT7 something like a "Baby Ongaku" from Sound Practices - but i am affraid the this will not be enough to drive 2 pieces of 2A3 in parallel.....
questions questions....
and not many answers....to bad....
Old 28th August 2008, 11:31 AM   #5
sunrise's Avatar
o.k. - i have found the sch for the parallel 2A3 SE using one D3a penthode connected as triode in front of them....
D3a is a bit problematic to find so i have searched...
I found that E280F is similar and also E180F seems to be usefull....
But there is a problem - can someone suggest me the best operating point for E180F and E280F when connected as triodes and when driving two 2A3's connected in parallel....
Old 28th August 2008, 12:01 PM   #6
Ciu is offline Ciu  France
Hello Sunrise !
May be here , where Ciuffolli got them :
http://search.stores.ebay.fr/classic...822955QQsofpZ0
R.C.
Old 28th August 2008, 04:30 PM   #7
sunrise's Avatar
yes yes.... thanks Ciu...
but i would rather want to use the tube that is not so rare like D3a....
so i have decided to use E180F or E280F (that is actually almost as rare as D3a).....to use them if possible naturally.....
so i am searching now for the best operating point to drive the parallel 2A3...
can somebody help me...
man, this place use to have people that actually helped.... i don't know what happened - maybe summer the vacations are still going and there is not that much people on the web....
don't know,...
but the problem stays to be solved....
so guys, please help if you know how.....thanks in advance...
Old 28th August 2008, 04:41 PM   #8
kevinkr's Avatar
Still plenty of people out there willing to help. We are a couple of days away from our end of summer holiday and a lot of people are away.
FWIW I am not a big fan of paralleling anything, particularly DHTs in the output stage of an SE amplifier.. I have heard some VERY expensive PSE amplifiers and have always preferred comparable non PSE designs. For about the same amount of money you could build a 300B based amplifier with the same output power.
The D3A in a DRD based circuit with a 300B would make a good, relatively simple amplifier project I think. (I use D3A for all sorts of purposes.) 3K opt.. 60 - 70mA cathode bias, raw supply about 500V, etc.
If you insist on going the 2A3 route you will want an output transformer with about 1.25K - 1.5K primary, tubes operating at 60mA each (120mA total) at an effective Vp of about 250V. Raw dc with cathode bias of 300V. How's that for helpful.
Jack Elliano of Electra-Print has details of the DRD design on his site:
http://www.electra-print.com/
Obviously he can also make the required chokes and transformers depending on where you are.
www.kta-hifi.net
Old 28th August 2008, 05:54 PM   #9
Yvesm is offline Yvesm  France
Yvesm's Avatar
Originally posted by PhilippeS
Hi Sunrise,
Yes, but triode strapped
Yves.
Old 28th August 2008, 06:22 PM   #10
sunrise's Avatar
i thought the summer holidays are the problem heheheheh.....i know that there is allways a lot of smart people that know how to help.... hehehhehe....
related the project.... yes - i would like to go with 2A3 in parallel - rather than with one 300B....
but i was asking for the good operating point for the E180F (or E280F) that can drive 2 2A3's in parallel.....or at least a good operating point for those two driver tubes mentioned.... i figure that E180F would be enough - in triode connection it would probably go with 50Vrms output for 1V (or so) input and that on 10-11mA bias current....right or not???
i am asking questions for E180F (or if it will not be enough for E280F) - hehehehehe
Yves.
of course.... triode connected
hehehehehehe
PSU Parallel Help SkippyDogg Power Supplies 8 11th November 2008 07:05 PM
PSU Parallel Help SkippyDogg Everything Else 0 1st November 2008 05:01 AM
parallel sub skyraider Multi-Way 1 28th December 2005 08:12 AM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 07:12 PM
Page generated in 0.13738 seconds (82.13% PHP - 17.87% MySQL) with 10 queries
