What's the biggest full wave damper diode?
Old 26th August 2008, 06:18 PM   #1
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
Default What's the biggest full wave damper diode?
Working on a big guitar amp finally, big enough to need a GZ34.
I was wondering if there was a damper diode alternative to that? I know about the 6CD3/6CE3/6CG3, but these are only half wave, and 2 would need lots of heater current. I know about the 6BY5, but that's only good for 175mA I guess.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of TotÚ? Umberto Eco
Old 26th August 2008, 06:55 PM   #2
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
6AX6? Good luck finding any... a pair of dampers would do as well.
Old 26th August 2008, 07:09 PM   #3
Rodango is offline Rodango  United States
Rodango's Avatar
Send a message via AIM to Rodango Send a message via Yahoo to Rodango
My personal favorite is the Soviet Svetlana 5C3S. They are 5U4s on steroids and can be obtained inexpensively on ebay.
Old 26th August 2008, 07:35 PM   #4
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
'cept that isn't a damper --^
there isn't really fullwave dampers as such, because you only need one damper diode in a TV...
Old 26th August 2008, 10:10 PM   #5
mashaffer is offline mashaffer  United States
Just for my edification what makes a damper diode different from any other vacuum diode?
The only reason I drive the 91 Colony Park is that I can't afford a 65. Me old school? Couldn't be.
Old 26th August 2008, 11:00 PM   #6
mcs is offline mcs  Denmark
Slow heat-up, low internal impedance (= low voltage drop), and a good heater/cathode isolation so you can use a common heater supply.
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 26th August 2008, 11:22 PM   #7
DougL is offline DougL  United States
A damper diode (or efficiency diode in Europe) was used in TV in the horizontal output stage. The circuit was high voltage, high current, low pulse duration service.
Understanding the Horizontal output stage
HTH
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 27th August 2008, 12:19 AM   #8
Eli Duttman is offline Eli Duttman  United States
Default Re: What's the biggest full wave damper diode?
Dude,
The 6BY5 is good for 175 mA. continuous DC per plate. Carefully peruse the 6BY5 data sheet.
BTW, Chinese made 5AR4s from reputable dealers, like Jim McShane, are both reliable and reasonably priced.
Eli D.
Old 27th August 2008, 12:24 AM   #9
vanofmonks is online now vanofmonks  United States
What about the 6by5?
Chris
Old 27th August 2008, 04:03 AM   #10
athos56 is offline athos56  United States
athos56's Avatar
I'm using a pair of 6D22S's in my new project
What's the biggest full wave damper diode?Hide this!Advertise here!
Damper Diode Musings Eli Duttman Tubes / Valves 12 21st February 2005 05:08 AM
Full wave vs full wave bridge rectifier jeff mai Parts 31 11th February 2005 11:43 PM
5v Damper Diode? G Tubes / Valves 11 7th June 2004 02:18 PM
