diyAudio Sponsor
Old 26th August 2008, 05:19 AM   #1
regal is offline regal  United States
Default DAC - tube gain stage w/ AC heaters
Building a 6N6P tube gain stage which takes a 200 mV p-p input signal. CCs plate load gain =22.
I had planned on using AC for the heater but am having second thoughts, should I place a Digikey order to build this as DC heated?
Old 26th August 2008, 05:28 AM   #2
dsavitsk's Avatar
Give it a try and see what happens, but I generally use DC in this position. Note that if all you have is a 6.3VAC winding, unless it is way overspec'd in terms of current, you will have trouble getting 6.3VDC.
http://www.ecpaudio.com
Old 26th August 2008, 07:03 AM   #3
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
My tube output stage for the Marantz CD63 used AC heaters with no hum noticed.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 26th August 2008, 11:28 AM   #4
Tweeker is offline Tweeker  United States
Float the heaters +30VDC from a voltage divider from B+ and use AC (or DC, either way floating the heater reduces noise coupling to cathode).
Be sure your foil hat has a good low impedance ground.
Old 26th August 2008, 11:42 AM   #5
Yes a planned on floating the AC heater, the transformer doesn't have a heater CT but I will just tie one end to the B+ voltage divider.
With amplifiers I have built in the past even when floating the AC heater, I still measure a -60db bump around 60 hz. I can't hear it but only measure it. My concern is feeding the amp with a tube DAC that also has this bump, the 60 hz hum may be multiplied.
Old 26th August 2008, 12:30 PM   #6
zigzagflux's Avatar
I use that exact tube in a differential pair immediately following the I/V resistor (RAKK DAC II).
Originally used DC, elevated 35V. To conserve space and eliminate harmonics and heat dissipation, I converted over to AC. Absolutely zero hum.
Switch-mode PSU for tube heaters? deltavektor Tubes / Valves 9 31st October 2008 08:07 AM
Tube heaters in series. nigelwright7557 Tubes / Valves 5 4th July 2008 09:11 PM
Tube heaters AC or DC? soundbadger Tubes / Valves 105 1st March 2008 10:04 AM
purple tube heaters... vixr Tubes / Valves 34 7th December 2007 12:49 AM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
Page generated in 0.28714 seconds (91.11% PHP - 8.89% MySQL) with 10 queries
