| diyAudio Sponsor | ||
Folks,
I am looking for a picture of the insides of Tango transformers or information on how they are assembled - reason being I have to fix two units that were damaged in shipment. The cover (can) has two small retaining screws that attach to some kind of bracket/clip on the base. Does anyone know if they are normally potted? Would the can lift straight up? There is continuity across all windings, but I am afraid of damaging them if I try to remove the cover which was damaged in transit. TIA, -- josé k. |
#2 |
If you can show the type number, it would be easier to tell something about the inside construction.
#3 |
Konnichiwa,
Model number is FW-20-14S. Primary Z: 14K Secondary: 4,8,16 Freq. Resp. (-2dB) 30Hz-35KHz Current: 30 Tubes: 801A, VT62, VT25, 10Y Duomo. -- josé k. |
#4 |
Here is a picture of the damage.
#5 |
I also have the transformers in my 801A single amplifier.
To remove the cover, just take off the side screws in your photo. Then you can remove the cover just pulling upward. You will find an internal bracket to fix the coil form without breaking any wirings and mechanical parts. Good luck! |
#6 |
Will do - thank you very much. Please email me offline and let me know the details of your 801 amp.
Best regards, -- josé k. jose_korneluk@bellsouth.net |
#7 |
OK, I have just sent you an E-mail. Enjoy!
| Tango transformers set for Sishido/Wavac 805 tube amplifier | AD | Swap Meet | 1 | 24th January 2010 08:26 AM |
| Got a box and speakers but need help with the insides. | nubbins | Multi-Way | 0 | 18th October 2007 11:24 AM |
| Tango transformers for sale | dariusku | Swap Meet | 0 | 7th August 2007 11:10 AM |
| TANGO MOSFET OP Transformers!!! | brianco | Swap Meet | 3 | 9th March 2007 11:28 AM |
| Page generated in 0.08129 seconds (74.22% PHP - 25.78% MySQL) with 11 queries |
