diyAudio (
-   Tubes / Valves (
-   -   Blumlein's Garter Bias question (
jkeny 24th August 2008 10:03 PM
I'm going to try this biasing method on a PP ECL86 which currently uses 270R bypassed with 470uF caps on each tube.
I know I need to change the 200 Rs in the diagram to 270 but how do I determine the correct value for the 100K R?
kenpeter 24th August 2008 11:53 PM
I am not sure if you have given us sufficient information.
What is your B+, how do you have the screens strapped?
Are you intending bias for Class A, Class AB, Class AB2?
If I knew idle current or bias voltage, I could guess the
other from the 270R's. But I can't calculate what is your
intention from knowing just the cathode resistors.
jkeny 25th August 2008 01:19 AM
2 Attachment(s)
OK, I forgot to include this - bias is 27mA in class A on a baby huey circuit attached (390R bias R on diagram is actually 270R)
gingertube 25th August 2008 01:52 AM
This scheme puts half the bias from the other push pull side onto the grid. Thus rather than (approximately) having the grid at 0V DC and the cathode at +14 DC you want +14 DC on the grid and +28V DC on the cathode. So BOTH cathode resistors need to be the same size as you are now using. So use 2 x 270R for each cathode.
The 100K shown need to follow the max Rg1 values for the tube - For ECL86 take those 100K up to 470K.
jkeny 25th August 2008 01:55 AM
Edited out some text
Thanks for the info on the 470K.
Have you tried this biasing method?
Will the feedback R need to be changed?
jkeny 25th August 2008 02:11 AM
I may well try Shoog's variation on this biasing seen here:
kenpeter 25th August 2008 06:17 AM
R14 1M keep that series pair of 1000uF (electolytics I would
assume) bridged across the cathodes with a safe DC bias?
Resources saved on this page: MySQL 18.75%
