Too low heater voltage?
Old 24th August 2008, 08:12 PM   #1
jkeny is offline jkeny  Ireland
Banned
Default Too low heater voltage?
I'm at the final stage of building John Swenson's BDT pre-amp using 6AR8 TV Beam Deflection Tubes datasheet here: http://www.r-type.org/pdfs/6ar8.pdf
I'm installing it in an existing amp chassis for an integrated amp & space is at a premium. The heater voltage is 6.3V (300mA) which is best fed DC for hum prevention. I have a small SMPS of 5.8V 1A which I wanted to use
Is this voltage too far off the mark & could it lessen the life of the tube or starve it of space charge? How low is too low?
There is an existing 6.3V from the PS trafo which runs A/C to 4 ECL86 tubes (4*660mA cureent = 2.6A) & also powered the original preamp 3 ECC807 (3*300mA) before I removed them. So it should be powerful enough to feed the 2*6AR8 tubes (2*300mA)
I have a problem using this:
- I can't mix the existing 6.3V A/C supply and create a 6.3V D/C supply off it because 1 leg of the DC is grounded?
- I can't go DC all the way because 3.6A is a bit too high for simple 317 regulators.
Any ideas?
Old 24th August 2008, 08:23 PM   #2
mcs is offline mcs  Denmark
Default Re: Too low heater voltage?
So use a 5A regulator like LM338?
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 24th August 2008, 08:31 PM   #3
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
Default Re: Re: Too low heater voltage?
By the time you have sufficient capacitance, high current diodes (probably with heatsinks), and the necessary heatsink on the regulator, this will be a large, expensive, and hot solution.
Have you tried just doing AC all around? Do the normal of good lead dress and bias the heater up a few volts, and you may be fine.
Otherwise, 6AR8's are on sale at http://tubesandmore.com for $2.50 each. I say run them at 5.8V, buy a bunch, and replace them slightly more often if need be.
Old 24th August 2008, 08:57 PM   #4
Banned
338 soultion is going to be too big as dsavitsk says - not an option.
A/C is a no-no according to John Swenson- hum sensitive tube even with good lead dress.
I'll try at 5.8V and see how it goes while looking for a small 12V SMPS which I can regulate down to 6V (I'll probably only ever run it at this lower voltage for better sonics, maybe?)
I wanted to give a SMPS a go for cleaner heater supply?
Do I need lots of capacitance on the output of the SMPS to kill any noise though?
I know 6AR8 tubes are cheap so I could buy a bunch as you say!
Old 24th August 2008, 09:04 PM   #5
An LC filter would be a good idea (if there's room for the L).
Best regards,
Mikkel C. Simonsen
Old 25th August 2008, 04:23 AM   #6
SpreadSpectrum is offline SpreadSpectrum  United States
SpreadSpectrum's Avatar
I just did a 3.2A 6.3V lm338 supply and I agree it will take up a lot of space to do well. I was planning of fixing up an old integrated amp and was going to make a separate box for the heater supply. I was also going to run the AC for the amp go through the separate box so that I could do standby switching though that separate box as well. That way I could keep it looking original but still have everything work as I want it to.
You want to look at how much plate current you have with these tubes you are going to run at 5.8V. If you are way below limits, you should be fine. If you are pushing the limits, you may damage the cathode.
Oxide coated cathodes are meant to be protected by a cloud of electrons. If you deplete that cloud, nothing stops ions in the tube from smashing into the cathode and damaging it. Running the heater at a lower voltage makes that cloud smaller and easier to deplete. Again, not a problem if you run the tube conservatively.
Old 26th August 2008, 12:08 AM   #7
Banned
Actually it seems like 5.8V is fine - tubecad goes as far as to suggest 5V is even better! http://www.tubecad.com/july2000/page10.html
There is a graph showing transconducatnce over time with the 5V showing the flatest line line i.e least decline
Why not try a 5 volt heater power supply and see if the extended life and greater consistancy in Gm, albeit lowr Gm, is not worth the effort.
I can live with the lower Gm so I'll give it a go!
Too low heater voltage?Hide this!Advertise here!
DC Heater Voltage Bengali Tubes / Valves 9 2nd February 2009 04:19 AM
heater voltage Jaap Tubes / Valves 3 18th November 2008 11:39 PM
Need Help Setting Heater Voltage cgrums Tubes / Valves 10 25th January 2008 05:40 PM
DHT heater voltage zobsky Tubes / Valves 23 9th September 2006 03:55 PM
heater voltage: why ac, and not dc? alex278 Tubes / Valves 18 7th October 2005 12:21 PM
Copyright ©1999-2017 diyAudio
