diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   ECC40 driver stage for 2A3 (http://www.diyaudio.com/forums/tubes-valves/128575-ecc40-driver-stage-2a3.html)
cypher 23rd August 2008 08:20 PM
I have decided to change driver stage in my 2A3 amp, instead of ECC81 I was trying to use ECC40.
I applied ECC40 in SRPP but unfortunately this setup hasn’t sound good. Perhaps this is not the best tube for SRPP. Perhaps someone could help me and point appropriate way to use this very tube..
Thank you ;-)
Artur
Hi_Q 23rd August 2008 08:39 PM
According to the info provided here-
http://www.r-type.org/pdfs/ecc40.pdf
This should be a great valve for the purpose you intend. I have a couple of them myself but no bases for them so they have stayed in the proverbial junk box. I note that the article at the above web site has some advice on instability that may result from using the valve and warns of careful wiring layout and perhaps provision of neutralising capacitors. It would be great if someone on this Forum has had specific experience with this valve as they may be able to offer you some further practical advice.
andyjevans 23rd August 2008 11:11 PM
I've used the ECC40 in differential pairs with a constant curent sink under and it sounds superb - better than anything, including the E80CC. It's my favourite small tube and I listen to it every day in my amp. I never tried SRPP though, and in general I've stayed with lowish HT and currents, using it with plenty to spare. It has lovely treble.
Andy
cypher 24th August 2008 07:56 AM
Hi Andy,
Could you possibly post schematic with parts and their values ?
I’m sure that more people would be interested in.
Artur
Resources saved on this page: MySQL 18.75%
