diyAudio Sponsor
Old 23rd August 2008, 07:44 PM   #1
Miniwatt's Avatar
Default heater current and 6922 - 6n6p swap
Hi all,
I posted this in digital, this is probably a better place
My Audio Note DAC 1 uses 6922 / 6DJ8 tubes. I want to swap them for russian 6n6p's. Pinout is practically the same, but where a 6922 uses 300 mA for the heaters, a 6n6p uses 750
The power transformer only has voltage ratings, so I'm wondering if it can take that
Anyone? Thanks
Old 24th August 2008, 01:36 PM   #2
hey-Hey!!!,
If your heate winding will deliver the 6.3V with the 6H6Pi and doesn't get too hot, you'll be fine. I doubt it will though, you're looking at nearly an amp more to the load.
cheers,
Douglas
the Tnuctipun will return
Old 25th August 2008, 02:52 PM   #3
Miniwatt's Avatar
Thanks!
Old 25th August 2008, 03:07 PM   #4
hey-Hey!!!,
I thought of a few things too late to edit. Sort of confirmation/proceedural stuff. Measure voltage on the pins( 4&5) with the 6922 installed, and then with 6H6Pi installed. If there is not a lot of change( like perhaps the 6922's running 7V and the 6H6 dropping to 6.2V), I'd feel better. Add this all to the heat warning, but keep in mind 'hot' for a power TX is ~boiling water; so if you can keep your hand on it( again, be aware of change from baseline; lots hotter is a risk ).
cheers,
Douglas
29GK6 heater current? bst Tubes / Valves 6 4th October 2010 02:21 PM
6DJ8 / 6922 swap for 6n6p (russian) in AN dac1 Miniwatt Digital Source 0 23rd August 2008 12:23 PM
Variable 6922 heater to cathode voltage limit...? ashok Tubes / Valves 2 13th April 2007 08:16 AM
Heater supply recommendation for 6922? leadbelly Tubes / Valves 18 20th March 2007 02:14 AM
6922 Heater - BIAS mickie Tubes / Valves 3 11th July 2006 10:35 AM
Page generated in 0.07337 seconds (73.29% PHP - 26.71% MySQL) with 10 queries
