diyAudio Sponsor
Old 22nd August 2008, 10:49 AM   #1
vega65 is offline vega65  Norway
Talking 813 trioded Datasheet and curves
Hello
I am looking for datasheet and curves for the 813 trioded.It seems to be a little hard to find.I have found some old links but they are all dead...
Old 22nd August 2008, 10:51 AM   #2
diyAudio Moderator Emeritus
Bas Horneman's Avatar
They can be found on my site
http://basenjes.de/tubes/813.htm
Old 22nd August 2008, 12:00 PM   #3
Wow thank you so much for a very fast reply. I am writing on my mobile phone . On my way to the mountains for a quiet weekend . I am about to check out the possibilities for making a se amp with this tube .will return with more about the project later
Old 22nd August 2008, 12:04 PM   #4
Enjoy your weekend!!!
Old 22nd August 2008, 03:57 PM   #5
I too am waiting to build an amp with the 813.
One of the big questions is AC or DC filaments.
DC filaments are going to be 50 watts, so think BIG heatsinks and corresponding ss devices.
Who can offer opinions on whether AC will hum too much?
My speakers are about 86db efficient so hum might just about be inaudible.
Ideas?
andy
Old 22nd August 2008, 04:40 PM   #6
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
Ideas?
andy
mmm ... CLCL filtering doesn't need heatsinks
Old 22nd August 2008, 05:33 PM   #7
So for a PP amp I need 4 chokes just to start with, and 8 chokes for CLCL.
Any idea what size in Henries and where I get these things? I know current is 5 amps, but what value in Henries is large enough to be useful? Farnell just lists CMCs at up to 3 mH which doesn't sound very useful.
Andy
Old 22nd August 2008, 07:13 PM   #8
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
I have a 813 se amp and it has DC heater supply.
Old 22nd August 2008, 07:30 PM   #9
rdf is online now rdf  Canada
rdf's Avatar
Hi Koifarm. Is that amp of Asian manufacture? The picture suggests the outputs are the massively heatsinked FU-13 variant. How do you like it?
Ears aren't microphones.
Old 22nd August 2008, 08:09 PM   #10
Hello
I am also planning to build a trioded 813se. I have been using Paul's curves when doing the basic calculations (many thanks 7N7)
As I wasn't sure about the status of my tubes and they are after all Philips QB2/250, listed as eqvivalent to 813 but you never know...AND I am planning to go A2 as well so I started to measure a set of curves myself.
(If I could just figure out how to post files here I could share them. Anyone knows why some members have problems posting files. Yes they are smaller than 100K and they are .jpg and should be OK)
The curves are generally somewhat "less steep" than Pauls. If this is because the tubes are used or because they are QB2/250 I don'know. (I have four pieces from at least two sources and they all measure within 5% from each other.)
One interesting thing is that I do not see the somewhat strange tightening between the curves VG=0 and -10. There IS however some 0,5-1 mA grid current at Vg=0. So a low impedance driver with no caps is recommended if you want to get "full" A1 power.
I am also interested in the heating issue, if anyone have any good ideas, without cooling fans and the need of forklifts for installation, please share them.
I will start breadbording with AC filaments so if you aren't in a hurry I will post some feedback o hum levels when it's done. (don't have too much spare time right now)
/Olof
I'm not allowed to do magic, union rules...
How do these curves look? astouffer Tubes / Valves 23 11th June 2009 09:52 PM
5-125 UL curves anyone? dowdylama Tubes / Valves 2 10th October 2008 11:43 AM
Derive Triode Curves from Pentode Curves? dsavitsk Tubes / Valves 3 14th May 2007 06:10 PM
Curves, curves, and more curves CarlyBoy Tubes / Valves 5 1st December 2006 10:11 AM
where's the curves? bostonswoop Multi-Way 13 13th March 2006 12:32 AM
Page generated in 0.60265 seconds (15.75% PHP - 84.25% MySQL) with 11 queries
