| diyAudio Sponsor | ||
This doesn't look real reliable to me. Bought a batch of 46's, and there are a number of them with the getter material that is coated on the inside of the glass broken off. Tried to get a good picture of this.
The valve appears to bias up properly, but I haven't put it into an audio circuit. There is shrapnel inside the glass, which I also took a picture of. Do I request a refund ? Thanks. |
#2 |
Another shot of the shrapnel.
#3 |
i do not know if this will shorten life of those tubes
but thinking glass there are many antique sorts of glass that has got a cosmetic imperfect look and still works as good as any glass there are ancient 1.000 years old chinese glass and you name it glass can be very different - there is no such thing as: a pure glass because always is some mixture, blend used now the life of tubes is not determined by the glass is other thing that becomes of age unless some body else, who knows audio tubes better tell you different then you can use them those tubes valves, just like the better looking when comes to electronics - the look has very little to do with performance unless something looks broken or faked there are some faked semiconductors, you know and even tubes are semiconductors - and an older semiconductor technique than transistors
lineup |
#4 |
Does the shrapnel move? If it is stuck fast then i would think they are safe. If however it is free to move about i would personally regard them as unsafe incase some of the shrapnel droped into the active part of the valve. However i'm no expert so i would wait until sombody here with more experience come's to your aid.
Leigh
The perfect amplifier is a piece of wire with gain.... |
#5 |
I've seen this from time to time, but not all that common. The getter flash has separated from the glass - and I'm not sure how easily that can happen.. (I'm wondering whether these were stored for an extended period of time in unheated space where it might have gotten very cold.. IIRC the examples I have seen that had this problem were stored in locations subject to very low temps during some part of the year. i.e. Garages, outside sheds, and unheated trailers.)
I think you ought to at least ask for a partial refund as I would consider this to be a defect, and possibly more than just cosmetic. Returning them is not out of the question. Not sure how conductive the gettering material actually is but it could create leakage paths on the micas that might result in noisy performance. I would check any you plan to use very carefully to ascertain where it has ended up.. If any of that stuff gets inside the structure of the tube it could be very bad news.
www.kta-hifi.net |
#6 |
Thanks Kevin-
I suspected as much, but am not sure of the conductive properties of the material. It does not appear to be free moving, but the flakes are stuck to the glass. I will contact the seller, and see where this goes. |
| Building a Line Array, what should I be concerned about? | The Paulinator | Multi-Way | 8 | 23rd July 2008 05:09 PM |
| How concerned should I be about load impedance? | cdwitmer | Solid State | 1 | 18th November 2006 03:13 PM |
| where to purchase CDM 3 & 4 ? | transitube | Digital Source | 1 | 26th December 2005 11:23 PM |
| Concerned, Please Help | Fazorcat | Subwoofers | 8 | 4th February 2005 04:51 AM |
| Page generated in 0.10303 seconds (76.48% PHP - 23.52% MySQL) with 11 queries |
