| diyAudio Sponsor | ||
diyAudio Moderator Emeritus
Has anyone seen the AR D4 schematic? It's an all-balanced design that uses as a phase inverter a "preamp" to one side of the PP input stage. I've never seen anything like it before. It's too big to post here, it will have to be a link. It's that scruffy-looking ECC81 (12AT7) that's squeezed into the bottom left corner.
#2 |
That is only a phase inverter with a gain of one.
Reinhard |
#3 |
At first glance, I thought it might be a 4th circuit inverter.
But its nothing so glorious. 1st half Y1 (ECC83) tries to -multiply input by Mu of 100 2nd half Y2 (ECC81) tries to cathode follow that Mu. But the input and output feed together op-amp style through the 301K and 316K resisistors to a unity (-1) local loop gain. |
#4 |
R.I.P.
Audio Research strikes again!
Thisi s absolutely nothing new, and about as complex and excessive as you can get. KISS in reverse seems to be A-Rs claim to fame... Regards, Allen |
#5 |
Looks like another clone of the Worthen phase splitter. It may provide good balance once set up with the right tube, otherwise a replacement will require test equipment to re setup. A major disadvantage. Not my ideas.
richj |
| Audio signal splitter (for preamp) | Krislarsen | Analog Line Level | 3 | 21st February 2006 12:25 PM |
| Not enough Digital audio inputs, can I use a splitter? | Snootleather | Digital Source | 2 | 27th November 2003 10:32 AM |
| Strange phase splitter design !?!? | Glass_painter | Tubes / Valves | 6 | 22nd April 2003 01:19 PM |
| Page generated in 0.07414 seconds (72.79% PHP - 27.21% MySQL) with 10 queries |
