diyAudio Sponsor
Old 14th August 2008, 01:11 AM   #1
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Default Para feed choke
Ok I have been looking for info on selecting a para feed choke but haven't had any luck.
So how do you figure the inductance needed in a para feed choke?
Thanks,
Nick
Old 14th August 2008, 01:35 AM   #2
If you pop over to Audio Asylum and search the Bottlehead forum for posts containing "parafeed" by Paul Joppa or Doc B or Voltsecond, you'll find all you need.
Best regards,
Mike Spence
Old 14th August 2008, 01:43 AM   #3
nhuwar's Avatar
Thanks will do
Para-Magnetic Current Amplifier Tyimo Solid State 14 13th January 2008 09:55 AM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
Swinging Choke or Smoothing Choke danFrank Tubes / Valves 4 11th February 2007 11:05 AM
Parallel feed (choke load) in output stage yagoolar Tubes / Valves 27 17th March 2006 10:49 AM
measured thiele para sonu Multi-Way 12 28th June 2004 09:28 AM
Page generated in 0.07002 seconds (66.92% PHP - 33.08% MySQL) with 10 queries
