| diyAudio Sponsor | ||
I have a pair of GK71 waiting to be used in an SE amplifier.
I would like to know if any members of the forum have used the GK71 in an SE in triode mode and what they found was the best output impedance for the output transformer and what voltages and bias were used? |
#2 |
Hello,
In my construction I`ve used 3k primary resistance transformer with UL tap on 20% from B+. Circuit run`s nice in pentode mode (Va = 1kV, Ia = 125mA, Us2 = 400V, Us1 = -48V, I reached an 42W on output still operating in A1 class. Connecting G2 to UL tap of tr. power drops down to 35W but sound quality .... huh .... Of course in triode mode internal resistance of tube drops drasticly, so I sugest to use 5k primary res. tr. |
#3 |
KK84
Thank you for your reply. I was planning to use the GK71 in triode mode. I found GK71 triode mode curves and calculated load lines for 5K, 6K and 7K. I have plotted them on the triode curves. I calculated the Rp at 1283 Ohm, the mu at 6.22 and the gm at 4.8 mA/V. The 7K load line gives the lowest 2nd harmonic distortion (around 2%) and looks like the best candidate for triode mode. The 3K OPT you tried seems very low for pentode mode. If the sound was good than the GK71 is a very forgiving tube. However designing an SE output transformer with 7K impedance with good specs with a lot of DC current and sufficient insulation, proved more difficult than I anticipated. I thus decided to go for 100 mA, 800V and a bias of -130V. What amplification stage and driver did you use in your amp? How much drive voltage did you put on G1 in pentode mode? Any problems with grid current, requiring a cathode follower? Did you experience any hum problems with the filaments of the GK71 (rectified)? |
#4 |
KK84
Thank you for your reply. I was planning to use the GK71 in triode mode. I found GK71 triode mode curves and plotted load lines for 5K, 6K and 7K. I calculated the Rp at 1283 Ohm, the mu at 6.22 and the gm at 4.8 mA/V. The 7K load line gives the lowest 2nd harmonic distortion (2%) and looks like the best candidate for triode mode. The 3K OPT you tried seems very low for pentode mode. If the sound was good than the GK71 is a very forgiving tube. However designing an SE output transformer with 7K impedance with good specs with a lot of DC current and sufficient insulation, proved more difficult than I anticipated. I thus decided to go for 100 mA, 800V and a bias of -130V. What amplification stage and driver did you use in your amp? How much drive voltage did you put on G1 in pentode mode? Any problems with grid current, requiring a cathode follower? Did you experience any hum problems with the filaments of the GK71 (rectified)? Tubedog |
#5 | |
Try drawing the load line at 3k slope. Pentode likes a steep load line I've found. Still, 3k and 100 mA only leaves you swinging +/- 300V before you cut it off. I have an amp running the slightly smaller 4E27 in PP with 10k a-a, 40% U-L taps to g2 and 20% taps for E-Linear with B+ of 550V. Those tubes are pinned like 813, and my filament TX can be rigged for 10V instead of V easily. Sooooooon....813's. The bottles certainly look neat. cheers, Douglas
the Tnuctipun will return |
#6 | |||||||||
Hi.
#7 |
Seems a little late... but how did this GK-71 amp turn out? Any problems/issues? Any schematics?
the reason I am asking, I am curious to know how it sounds compared to the GM-70. |
#8 |
quikie32
The amp has still not been build. I ordered 2 pieces of custom made 7K SE OPT's, but they did not meet my expectations at all. Not to say that I was disappointed. I have decided that I will now rewind the OPT's myself. I plan to do that very soon and will keep you updated on the progress of the project. I have collected a number of schematics and can post them if you are interested. |
#9 |
Ok Tubedog. Please post the designs. I am trying to build a GK71/GM70 amp. Was wondering if the GK71 could be trioded and run like the GM70.
| Someone help: SE shematic with GK71? | bezobraznia | Tubes / Valves | 30 | 24th April 2011 12:17 AM |
| GK71 B+ turn on delay | kk84 | Tubes / Valves | 4 | 2nd February 2009 07:31 PM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms | kelticwizard | Everything Else | 11 | 25th March 2007 05:17 AM |
| Page generated in 0.12620 seconds (80.88% PHP - 19.12% MySQL) with 10 queries |
