| diyAudio Sponsor | ||
Maybe a trivial question, but I could not find a simple answer:
Taking the curve family of a tube (triode, pentode) and for a given load line, how can I determine the output current versus input voltage curve? In other words: I have the anode current versus anode voltage curve family, where the parameter is the grid voltage. Now I draw a load line on the graph. It intersects the curves, and at each intersect point I can read the anode voltage and anode current for some discrete values of grid voltages. My question: how can I graph the anode current (or anode voltage) when the variable (x axis) is the grid voltage? |
#2 |
hey-Hey!!!,
Try transferring points to excel, then curve fit to get points in between. cheers, Douglas
the Tnuctipun will return |
| PL 519 electrical characteristics | Seraph | Tubes / Valves | 16 | 7th September 2011 07:41 AM |
| What would be a sensible set of filter characteristics for DAC | philpoole | Digital Line Level | 17 | 10th July 2009 09:05 PM |
| Plate characteristics | rossdt | Tubes / Valves | 8 | 7th August 2006 06:03 PM |
| 2A3 Sovtek characteristics | teodorom | Tubes / Valves | 16 | 17th July 2005 11:29 AM |
| Threshold voltage and transfer characteristics of lateral fet vs Hexfet | Circlotron | Solid State | 15 | 12th June 2002 09:38 PM |
| Page generated in 0.07442 seconds (66.94% PHP - 33.06% MySQL) with 10 queries |
