diyAudio Sponsor
Old 11th August 2008, 04:57 PM   #1
Default Stepped airgap choke ?
Hi
I took a close look at one of my scrapbox chokes and found that the airgap is sectioned in two steps (see pix).
What is the purpose of this ?
Is this a swinging choke, or .. ?
How does that influence the properties of the choke ?
Brgds
Pix
Pix
Old 11th August 2008, 06:26 PM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default Stepped gap?
I doubt it very seriously that this is a "stepped gap" TX rather it is probably a poorly 'reassembled' stack, notice the iregularly stacked laminations & the gap on the left inner stack in the middle.
This TX will perform poorly as it is not stacked 'right' it needs to be taken apart & realined correctly.....somebody did try to reassemble it & got it wrong.
It is very tricky to get it aligned right....& you'll probably find it will come apart easily as it seems it has been apart once already.
______________________________________Rick........ .
Interesting concept of a stepped gap however!
Old 11th August 2008, 06:42 PM   #3
Richard,
Ok, I might take it apart and tap the laminations flat, and reassamble it.
I dont have the equipment to measure it with DC current (just a AC bridge)
So, I have to aim for the airgap which are at the sides of that middle "tapp".
I measured 25mH/0,3 Ohm, So I thought it could be a nice heater choke for 2-3 Amp.
Brgds
Pix
Sweden
Pix
Old 11th August 2008, 09:01 PM   #4
Tom Bavis's Avatar
Looks to me like it was intended to have a dual gap. This will maintain some inductance to a higher current, giving regulation over a wider current range - essentially it's a swinging choke.
Old 12th August 2008, 06:07 AM   #5
Default Laminations
It just seemed to me the stacks were kinda inconsistant, note the overlap on the lams.
So this is the design of the famous 'swinging' choke huh? Cool, now I know.....what to look for too!
_______________________________________Rick....... ...
Old 12th August 2008, 08:45 AM   #6
diyAudio Moderator Emeritus
ray_moth's Avatar
Is it? I thought a swinging choke was just a choke with a narrower than normal gap, so that its inductance would fall more quickly with increased current?
Old 12th August 2008, 09:12 AM   #7
Default So perhapps I should left it as it is then
Well, The two step airgap distance is about the same at both airgaps (top and bottom), and also the varnish is intact, which speaks for that this type of airgap was intended from the manufacturing of the choke.
Of course, it could have been a badly assembled choke from the beginning, but sins the varnish is intact, at least it was not damaged by a drop or so by the user.
This choke was originally a part of a psu-box to a traffic-light from the 60-ties. Unfortunately I dont have the schematics left. But from what I remember there was a lot of high current inductors in this PSU-box. I think the purpose of this box was to regulate the voltage for the Lights.
Brgds
Pix
Sweden
Pix
Old 13th August 2008, 01:09 AM   #8
hey-Hey!!!,
I think the swingers saturated their cores gradually. That implies a varied gap, and enough turns to stand some AC. I don't think it would matter how the gap was different, just so as not to saturate it at a single DC current value.
cheers,
Douglas
the Tnuctipun will return
Airgap for filament transformer ? Lauscher Tubes / Valves 11 29th April 2009 05:41 PM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
Swinging Choke or Smoothing Choke danFrank Tubes / Valves 4 11th February 2007 11:05 AM
Stepped Gap Choke ChocoHolic Power Supplies 6 26th June 2005 10:30 AM
Airgap in transformers? Loial Power Supplies 7 23rd December 2004 10:13 AM
Page generated in 0.10736 seconds (76.49% PHP - 23.51% MySQL) with 11 queries
