| diyAudio Sponsor | ||
Hi all,
I've finally got all my Aikido line stage parts together. Most of the circuit connections are automatic given JB's design and parts but before connecting the PS together on my desktop and testing voltages, etc. I was hoping some of you might be kind enough to look over the attached schematic. I expect there might be both glaring mistakes and possible changes worth making before going forward. Questions: 1. I've read in discussions that I should not connect the filament supply CTs to ground. I gather this is because the 5AR4 will prefer this. True? Is this a longevity issue? 2. Do I need to add caps and/or resistors before either high or low voltage go to the 5AR4? If so what values? 3. I plan on putting a fuse before each transformer. Their VAs are 147 and 43. Will I be ok with a 3.2A and 1A fuse respecively? 4. I have insulated crimp connectors, wire nuts, non conductive work surface. Any other precautions recommended for the test run? Thanks for the help. gary |
#2 | ||
Your voltages looked high. So I ran PSUD. Simply guessed on DCR . 80R for 5H and 60R for 2.6H. I got 260V at the point you labeled B+ assuming 40 ma total current draw of an Aikido 6SN7. The Q and step response looked good. Ripple looked to be about 9 mV. Overall it looks like you get it.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus |
#3 | |
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#4 |
Hi guys,
thanks for the replies. Indeed I mislabled the 5AR4 heater supply, it's 2.5V per rail. Attached is the PSUD2 model I ran. I'm probably making a mistake with the initial voltage. This will probably change when loaded, right? So what is the safest way of dealing with the CT leads? Just cap them and tuck them out of the way? gary |
#5 |
The spec sheet on the 6SN7s gives max plate dissipation for both plates at 7.5W. Does this mean I should make the 150 Ohm resistor in the B+ filter section a 30W for the 4 tubes? This seems a bit big. Am I calculating this correctly?
gary |
#6 | |
#7 |
No, you are not.
Current^2*R=Power. If 4 tubes are drawing 7.5w each with 295V B+: .102^2*150=1.5 1.5 watts dissipated, use at least a 5 watt resistor.
Be sure your foil hat has a good low impedance ground. |
#8 |
Thanks guys,
I ordered a 5W resistor and probably figured this out before but I find myself second guessing everything now. I'm still having trouble understanding when and when not to connect the transformer CTs to ground. If I don't connect the 300V CT to ground won't I then get 600V across the 5AR4 plates? |
#9 |
The high tension transformer is indeed grounded at center tap, this is the winding the plates connect to.
The filament transformer is NOT grounded, this is where B+ is drawn from. Often from the center tap. You have it correct as diagrammed.
#10 |
You'll have 600 volts across the plates either way. But you must ground the CT otherwise you'll have an open circuit. NOT true for the filament winding. Don't ground that.
| Check my work -- PCB for sub controller | nullspace | Subwoofers | 2 | 1st March 2009 03:32 PM |
| Please check my work :) | athos56 | Tubes / Valves | 11 | 17th August 2008 07:05 AM |
| Pentode CCS: Would somebody check my work? | nullspace | Tubes / Valves | 5 | 13th March 2007 05:26 PM |
| ELF (Check my work, please) | fortyquid | Subwoofers | 4 | 1st October 2003 07:48 PM |
| First time designing a sub, please check my work | mFinalHeaven | Subwoofers | 37 | 19th August 2003 12:14 AM |
| Page generated in 0.12408 seconds (82.72% PHP - 17.28% MySQL) with 11 queries |
