| diyAudio Sponsor | ||
#21 |
Second pic
#22 |
Bruce,
I'm guessing that the tube set is a 5Y3 rectifier, 2X 12AX7s, and 2X 6BQ5s. The phenolic PCBs are junk. Salvage the "iron" and the tubes. Buy a large, deep, plain Aluminum baking pan as the new chassis. I suggest you follow (more or less) the DECWARE SE84 model. Triode wire the O/P tubes and use 2 triodes (possibly a twin) for voltage amplification. GE used 2 small signal stages in each channel to deal with tone control losses. If you are lucky, a no NFB circuit will work. Frankly, I have my doubts about the quality of the O/P trafos. Mediocre O/P "iron" needs help from loop NFB, particularly in obtaining satisfactory bass performance. 2X 6GK5s will do nicely in a circuit with loop NFB. A single 12AV7 family type will do in a no NFB design. The least costly way to obtain control over both listening level and channel to channel balance is to employ a pair of single (mono) log taper potentiometers.
Eli D. |
#23 |
Eli,
You are right about the tubes. I like your suggestion but don't have the time right now. I'll put this in the parts bin. Thanks Bruce |
| Marantz SR 7100 DC | alex mm | Parts | 2 | 26th March 2010 11:10 PM |
| ka-7100 audiofiles | sparkeey | Solid State | 0 | 30th June 2009 02:35 PM |
| ev 7100 transformer | djronbxs | Solid State | 0 | 3rd January 2007 10:24 AM |
| McIntosh 7100 | tsai | Solid State | 2 | 8th March 2006 02:21 AM |
| NAD 7100 schematics wanted | macuk | Solid State | 0 | 9th July 2004 06:43 AM |
| Page generated in 0.08346 seconds (69.43% PHP - 30.57% MySQL) with 11 queries |
