| diyAudio Sponsor | ||
Besides the used ones on ebay, no one seems to make them anymore. A member here offered to sell me two, then backed out.
Anybody else have a pair they didn't need? If I have no luck, would it be ok to use metalized polys like Solen or Mundorf for cathode bypass. AB. |
#2 |
Hello , They do sell 80uf 500volts ac oil filled motorrun caps. I just did order a box. Some people in England did allready use them in the power supply and as an ultrapad cap. One of them did put a story about a drd px25 amp on this site as well. greetings, Eduard Capacitor and craft farm is an ebay shop that sells them |
#3 |
none |
#4 |
GE (Regal Beloit) makes the 97F8052; 100uF 240VAC
Could also try Capacitor Industries, http://www.capacitorindustries.com/c...r/default.html for a 370V cap. Their prices appear to be pretty good. |
#5 |
The dual capacitors from Capacitor Industries are pretty useful too - 2 values in one.
#6 |
If you're okay with old stock, Nebraska Surplus Sales has a selection here and here. I have dealt with them before, and they are reputable, but I am not sure of these caps.
http://audio.gotroot.ca/ |
#7 |
Thanks for all the help guys, Capacitor Industries is the only feasible one, only they have the exact value, but the price seems a little steep.
They have this one CBB65-370R107, so I emailed them for the price. They said $49 ea. Anybody ever used these, are they worth it. http://www.capacitorindustries.com/c...r/default.html AB. |
#8 |
All the sources for 100uF ASC have dried up?
Be sure your foil hat has a good low impedance ground. |
#9 |
I have used these in three of my projects. Great price, seller is good. 80uF 500VAC motor run capacitor ebay
#10 |
Hello,
The 80uf eyda will cost you 12 S$ each. Do a search on px25 drd amp and you will read some reports. Do you really need 100UF? If so you should pay 49$ Greetings, Eduard |
| Motor run caps. New, unused. 50uF and 100uF. | nodiak | Swap Meet | 1 | 30th January 2009 12:30 AM |
| Source for 100uf motor run cap. | audiobliss | Tubes / Valves | 3 | 31st July 2008 04:15 AM |
| Thorens motor runs backwards! | GhettoSQ | Analogue Source | 18 | 20th September 2006 05:56 AM |
| Mounting motor runs | jaymanaa | Parts | 1 | 30th May 2006 08:23 AM |
| FS Black Gate SKZ 350v 100uf/100uf x 2 capacitors | Mark Hathaway | Swap Meet | 0 | 1st March 2004 09:25 AM |
| Page generated in 0.10898 seconds (74.17% PHP - 25.83% MySQL) with 10 queries |
