| diyAudio Sponsor | ||
#11 |
You see you get two positive reports within 5 minutes. Give them a try before some audiophile company will rebrand them and ask Blackgate prices. Eduard
#12 |
It will be hard to get the people who are buying the capacitors to run motors with that routine.
Angela offers 50uF cans you could parallel, but really not much cheaper (except the scratch and dent items) than Capacitor Industries.
Be sure your foil hat has a good low impedance ground. |
#13 | |
Well I thought of using the 80uf also, but was told that I could lose some bottom end. Guess I have no choice. AB. |
#14 |
ok, I found them. I have 6 new and unused as per the below link, which is where I bought them from. I sent the seller an email to see if he had any left, but he has not repsonded.
So let me know if you still need them. |
#15 |
the link
http://cgi.ebay.com/New-100UF-100-UF...QQcmdZViewItem these are 100uf at 370volts ac or 600+ DC according to the listing. |
#16 |
I sent you a email.
AB. |
#17 |
http://www.machmat.com/sales/indexc.htm Check at the bottom of the page. I bought one 100uF from them a couple of weeks ago. It was after shipping and weak dollar conversion around $80. They ASC made in japan but to be honest, I doubt you can hear the difference.
| Motor run caps. New, unused. 50uF and 100uF. | nodiak | Swap Meet | 1 | 29th January 2009 11:30 PM |
| Source for 100uf motor run cap. | audiobliss | Tubes / Valves | 3 | 31st July 2008 03:15 AM |
| Thorens motor runs backwards! | GhettoSQ | Analogue Source | 18 | 20th September 2006 04:56 AM |
| Mounting motor runs | jaymanaa | Parts | 1 | 30th May 2006 07:23 AM |
| FS Black Gate SKZ 350v 100uf/100uf x 2 capacitors | Mark Hathaway | Swap Meet | 0 | 1st March 2004 08:25 AM |
| Page generated in 0.10358 seconds (78.15% PHP - 21.85% MySQL) with 10 queries |
