diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Super 6BG6 vs. 6550 (http://www.diyaudio.com/forums/tubes-valves/127710-super-6bg6-vs-6550-a.html)
wrenchone 7th August 2008 05:03 AM
Super 6BG6 vs. 6550
I've been doing a fair bit of messing about with amps incorporating a non-standard tube set, like the 6LR8 and screen-driven sweep tubes. I have a hankering to do a standard-issue triode-connected pentode amp, especially as I have a pair of 3k impedance Transcendar SE output transformers looking for gainful employment. These transformers have no screen taps, so UL is out of the question.
I have a bunch of the super 6BG6 tubes on hand as well as a quad of Reflector 6550WCs. Which is more likely to be the best sounding tube triode-connected?
SY 7th August 2008 04:00 PM
No SE experience here, but in PP, the 7027.... errr... super 6BG6 was quite a bit better than some NOS Tung-Sol 6550s I tried.
wrenchone 8th August 2008 03:08 AM
Very interesting, SY - according to scuttlebutt, the Tung-Sol 6550s are supposed to sound preety nice, so bettering them for a fraction (and a small fraction, at that) of the price is a real coup. What sort of output iron were you using?
On another note, do you think that the screens on the 6BG6/7027 would be troubled excessively by 400V B+?
SY 8th August 2008 07:00 AM
They'll laugh at 400V. I'm running them at 500V with no sweat. OPTs are Eico, 6k6 p-p.
Burnedfingers 8th August 2008 10:46 AM
I'm running matched 6BG6GA's in my Quicksilver converted 8417 amps in place of 6550's or KT88's. I'm also running 6BG6GA's in my Dynaco stereo 70.
I have learned to listen to SY. I just ordered another Quad of them and should receive them in todays mail.
whitelabrat 8th August 2008 07:12 PM
I'm using 6BG6GA's along with Hammond 1628SEA OPT's.
I compared them to SED EL84's, Shuguang 6L6GC's, and old Chinese KT88's. The 6BG6's won by sound and price. I had four, and then bought a bunch more.
On the same note I also tried some old Sylvania 8417's. Those were the best yet, but good luck on finding any.
wrenchone 22nd August 2008 06:15 AM
Which curves come closest to approximating the behavior of the super 6BG6 in triode mode? I want to get an idea as to what sort of bias winding I'll be needing on my power supply. I've been looking at the GE 6L6GC curves for clues.
GordonW 22nd August 2008 12:51 PM
Look for the Sylvania 6L6GC STR curves if you can find 'em. That's about the closest thing I know, to the plate structure in the "super 6BG6". Should work fine as a modeling tool...
BTW: I'd order a set of these... if I didn't already have a quad of Sylvania STRs... kinda obviates the need, I guess... :D
Gordon.
SY 22nd August 2008 01:00 PM
http://frank.pocnet.net/sheets/049/7/7027A.pdf
These worked for me.
Ohighway 2nd September 2008 11:39 AM
SY and Burnedfingers. Can you guys please contact me via email?
I've got several questions to ask about using the 6BG6GA tubes in a couple amps. I'd like to try them in my Quicksilver 8417 amps as I just don't want to have to deal with the 8417 issues, and because the EL34 conversion just doesn't sound promising. I'd also like to try them in a Stereo 70.... well..... just because.
thanks.
Resources saved on this page: MySQL 18.75%
