| diyAudio Sponsor | ||
I've build my 5687 line stage preamp. i attached the scheme below.
Please comment about this scheme... And if compared with the design in this forum, which one is better... Thanks a lot. |
#2 |
Unless money is very tight, you can do MUCH better than a Solen output cap.
#3 | |
Sheldon |
#4 |
6K is probably a little low for the load in the best of circumstances, but because you have left Rk unbypassed, the rp of the tube is in the 8K range making the load way too low. I would either bypass Rk with a suitable cap, or replace it with a LED.
http://www.ecpaudio.com |
#5 | |
http://www.diyaudio.com/forums/attac...amp=1218073742 |
#6 |
Oooppss sorry about the scheme.....
The output is from anode... Does anybody know how to make this scheme better ? thanks |
#7 | |
do you need voltage gain? If so how much? Note the the anode output inverts the phase. |
#8 |
check out this site
http://www.diyparadise.com/simplepreamp.html I built this design and added gas regulators to it. Look around the site and you will find the schematic and the power supply. When built as he designed it has ZERO noise. The chokes are an important part in the design and cost very little. I would eliminate the fancy caps and led and build as shown. When you are comfortable with it then dive into a CCS and see if there are any differences to be had. I believe if you do a search a thread should turn up here. |
#9 | |
Better in what way? And to whom? I know what i'd do. Get rid of all the nice and cosy carbon comps and Kiwame resistors. They help produce a pleasant but also very coloured sound. Put some Caddocks in place. Replace the anode resistor with a choke and experience a really serious improvement. Replace the diodes with mercury rectifiers or tv dampers. Obviously the entire PS will need redoing then. |
#10 |
Thanks a lot....
| 5687 fully balanced line stage | cedus | Tubes / Valves | 14 | 24th July 2009 01:28 PM |
| 5687 as a single stage SE amp | simonov | Tubes / Valves | 4 | 15th November 2006 09:26 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| 5687 line amp with 0D3 regulator | Original Burnedfingers | Tubes / Valves | 27 | 7th August 2003 01:51 PM |
| 5687 Line Stage | karma | Tubes / Valves | 16 | 3rd June 2003 09:44 PM |
| Page generated in 0.11874 seconds (78.10% PHP - 21.90% MySQL) with 11 queries |
