diyAudio Sponsor
Old 6th August 2008, 02:56 PM   #11
smoking-amp's Avatar
"According to Max Robinson, use of a CCS in the tail of a tube-based LTP allows NFB to be returned to the second grid without problems."
With the lowish loop gain used in tube amps, the input diffl. pair has to work over a larger region of it's characteristic curvature (than SS amps.), so matching of the tubes will be important so they both operate with equal currents and equal transconductances.
The CCS will need to be a cascoded one to avoid variable junction capacitance causing a "transistor sound" insertion at the tail. Even with ideally matched tubes and CCS, the diffl. pair still generates a little odd order distortion at signal peaks as its composite gain drops off a little.
Resistor differencing to the same input (ie, inverting node summing) avoids this odd order problem. But input Z goes down of course.
Neg. feedback to the cathode also has some subtle distortion concerns, due to the input grid/cathode transfer function not being perfect. In SS designs, neg. feedback to an input emitter or source (so called "current feedback" amps) are known for having poor distortion characteristics. But tubes have a more gentle non-linearity characteristic.
Don
Ohms Law V = I R
Old 6th August 2008, 04:07 PM   #12
SY's Avatar
Whatever distortion the cathodyne has is minimal since, like a cathode follower, it has a large amount of negative feedback.
I'll 95% agree. But if one makes the total load too small and the mu is too low, it can have appreciable distortion. It's easy to get it right, though; to a good approximation, one can estimate the distortion by looking at the same tube in common cathode, with the total load in the plate circuit. That distortion is then divided by mu + 1.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 6th August 2008, 04:51 PM   #13
50% iirc
Andrew
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 6th August 2008, 08:41 PM   #14
Miles Prower's Avatar
You have the same problem with cathode followers. The CF makes a good Lo-Z source for a Hi-Z load. The more heavily you load it, the less NFB you have, hence more distortion. With a cathodyne, it shouldn't be all that difficult to ensure it looks into a Hi-Z load. That's what the Williamson does.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 6th August 2008, 08:51 PM   #15
That's what I did with one design: cascoded 6BQ7s to form an LTP with cascoded BJTs in the tail for an active load. Connected the gNFB to the grid opposite the signal input. There were no problems.
www.dolphin-hsl.com
UcD like topology amp. Bender.ru Class D 232 21st March 2012 03:55 AM
cf topology lessons... pls help JojoD818 Tubes / Valves 21 30th April 2004 10:04 PM
Page generated in 0.08375 seconds (73.94% PHP - 26.06% MySQL) with 10 queries
