| diyAudio Sponsor | ||
I have literally hundreds of small signal BJTs on hand and am considering using them for the meter driver in my 6EM7 project. The PT for the project has a 45VAC bias winding that I am not using for its intended purpose. I am wondering if it would be reasonable to use it to provide power for about 1/2 dozen of these little guys.
The schematic of the PT makes it appear that the "winding" is just a tap off of the HT winding which also has 275V and 325V taps. If so then I suspect the current of a few mA should not bother the winding at all. Would you agree? I am somewhat concerned however that there might be some interaction from the rectification and filtering that would be reflected back into the B+. Is this a legitimate concern? If so what precautions would be indicated? Over all would I be better off to just take a voltage divider of the B+ for the tubes to derive the PS for the transistors? BTW does anyone have a nice BJT circuit for a VU meter driver? I am thinking of adapting the Elliot Sound Op Amp circuit for BJT. The meter would be switched between microphone input and output power monitoring.
mike - www.keepingsundayspecial.org |
#2 | |
Other than the tiny draw that occurs when the grid potential approaches 0 V., the tap is intended to provide no appreciable current.It's not like separate, low VA, trafos will break the bank. AnTek 10 VA toroids cost all of $10 each. $6.29 buys "Rat Shack" catalog # 273-1366, which you could Greinacher voltage double to power "gobs" of BJTs.
Eli D. |
#3 |
OK. I thought there might be trouble in paradise. I actually probably have an appropriate tranny lying around as I have salvaged a lot of solid state gear. I just didn't want to waste anything if it wasn't needed.
| Power Trans Winding Parallel AC or DC? | sylin | Power Supplies | 11 | 3rd March 2009 09:09 AM |
| NICE; Custom 250VA Toroidal Power Transformers; 34vac/7a, plus an Auxiliary Winding | dozer | Swap Meet | 0 | 19th January 2009 09:10 AM |
| Winding new power transformer for CarlosFM's GC Design | cwteoh | Chip Amps | 1 | 13th January 2005 02:15 AM |
| Sand sandwich | Vikash | Multi-Way | 48 | 10th April 2004 04:13 PM |
| Comments Please: Winding own audio power transformers | UncleJessie | Solid State | 10 | 9th August 2003 11:28 PM |
| Page generated in 0.07842 seconds (67.12% PHP - 32.88% MySQL) with 10 queries |
