Two 6J5 versus one 6SN7
Old 4th August 2008, 08:59 PM   #11
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
Wink I'd use the 6J5
but then I just bought 20 of them NOS and a cluster of NOS octal sockets, so I don't have much choice...
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 4th August 2008, 10:25 PM   #12
wa2ise is offline wa2ise  United States
wa2ise's Avatar
Use DC on the 6SN7 heater, then that hum problem should go away.
Either rectify and filter the 6.3VAC heater supply, or if the output tubes draw enough current, you could use the 6SN7 heater as part of the output cathode resistor.
Another trick to consider is to disconnect the 6.3VAC supply from ground, and to bias it up about +40V. Making the heaters more positive than the cathodes tends to reduce hum leakage. .
Two 6J5 versus one 6SN7Hide this!Advertise here!
ZRT 2 way versus 2.5 way s7horton Multi-Way 5 13th August 2008 06:23 PM
Diy Versus Comercial east electronics Solid State 0 29th April 2008 09:15 AM
One speaker versus two Mos Fetish Multi-Way 12 23rd August 2005 02:07 PM
TPP versus PSE. GeirW Tubes / Valves 11 27th November 2004 08:55 AM
2.5 way versus 3 way Mos Fetish Multi-Way 1 6th April 2003 06:57 AM
