| diyAudio Sponsor | ||
I'm a newbie around here but have experience in electronics. Like most people I have significant gaps in that knowledge though. I have 3 related questions.
1. I want to create a balanced push-pull input stage so I don't have to deal with unequal output impedances from a single tube. The other reason I'm going that route is that its an easy way to create a constant current draw to that stage. Since I'm using a transformer attenuator as volume control to drive them there's no worries for a balanced grid drive. I plan on using leds to bias each 5842 cathode and a single IXSY CCS supplying both plates. My question is this: tubes are never exactly equal in current draw or mu and its also possible for each 5842 tube to age differently. What's the best way to handle this. I'm thinking a small value pot with one leg for each cathode but it seems like it defeats the purpose of using leds. Any ideas out there? 2. An informal line stage standard output seems to be 2 V rms which equals 5.8 V P-P. Yet I keep seeing threads here where individuals are using leds that don't equate to this standard. It seems to me that 2 leds approximating 3 volts is the way to go. Will that work for the 5842 tube or is it over biasing it? It seems like its a good idea to have some margin for transient peaks right at the input of amplification. 3. I'm midway in learning pspice but haven't yet learned how to model a generic CCS that computes. I'm not sure what I'm doing wrong. Any ideas? Thanks guys in advance.
#2 |
I should add that the P-P input, (is "P-P" preferred or "differential"?), is driving a P_P output. Duh!
#3 |
tarmac ripper
I am not sure I got that single CCS thing properly, but I'd rather use a single CCS under the cathodes of the tubes (i.e. differential pair). You will need a negative rail. Sorry for not answering to your questions.
Re Gianluca |
#4 | |
You hit on the same thing I was thinking. The CCS works best in the cathode load. Given equal plate loads( resistive that is ), one can even use dis-similar triodes. Say 6DN7 in place of 6SN7. If you can get the plate V matched with a biasing arrangement, they have excellent balance( quite a suprise when I first saw it ). All that took away most of my worry about tube aging and asymetrical changes in the performance. cheers, Douglas
the Tnuctipun will return |
#5 |
It sounds like I'm seeing the beginning of a consensus for not placing the CCS on B+ side. My original reason for doing that was that, at least in single sided amplification, it has a lot of advantages over the cathode side. But maybe you guys are right that in PP that doesn't apply.
I still would like to be able to cut down on the resistance in the cathode circuit used for biasing the grid, ala LEDs. Maybe I've been thinking about this all wrong and the CCS in the cathode side is just an alternative solution to LEDs that creates a similare advantage. Is there a way to think about it or implement it that could give me a better feel for this idea. Is a CCS in the cathode just another way of reducing dynamic resistance in this situation or am I thinking about this wrong? |
#6 |
tarmac ripper
Well, CCS's can help in PP anodes too. Old WE schematics used chokes, a passive CCS as a matter of facts, after the supply and before entering the B+ connection of interstage trannies (have a look onto the Lynn's paper on www.nutshellhifi.com)
The last PP amp I built had the cathodes grounded and the tubes biased with a fixed negative voltage at the grids. I could not make a direct comparison between cathodes CCS's and grounded cathodes unfortunately. OH! ... ground has a lower impedance than LEDs :-) Now I am following that path for all my amps and preamps even if they are SE: grid bias and CCS on anode or choke if a final stage is involved. Ciao Gianluca |
#7 |
You're thinking about it wrong.
In a p-p circuit, you want the signals at the anodes to be as equal-but-opposite as possible. To achieve this, what is commonly done is to use equal plate load resistors, then the highest possible impedance at the cathode, i.e., a CCS. If that cathode impedance is essentially infinite, a minute or two of sketching will convince you that the signals at the plate are indeed equal-but-opposite: the sum of the two tube currents must equal the cathode CCS current, so any reduction in one side MUST have an equal-but-opposite reduction in the other side, sicne there's nowhere else for the current to go (grids should not draw current here). Now, where a plate CCS really helps you in a single-ended circuit is reduction of second harmonic. For a p-p stage, the second harmonic components cancel at the output, so you pick up much of the advantage anyway, at least as long as the plate load resistors aren't excessively small.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more. - Christopher Hitchens 1949-2011 |
#8 |
hey-Hey!!!,
The plate Z is modified by the cathode impedance. If you put a CCS there, it is in parallel with the other cathode. Cathode Z is ~R_p/(mu+1), so for medium mu, high gm tubes the cathode Z modification to the plate Z is fairly small. cheers, Douglas
#9 |
Maybe I should start from the beginning how my thought process developed. As Gianluca aptly mentioned many of my ideas came from Nutshell hi-fi. The early WE P-P circuits there are modified by a CCS at the center tap of the primary on the interstage tranny. The explanation for implementing it that way was that a CCS creates a much more linear load impedance for the tubes to work against. In fact with a perfect CCS the load would be a horizontal line instead of the deeply slanted line you usually get.
Now, I don't plan on using an interstage transformer but I figured capacitor coupling would work equally well for that topology. I think the only fly in the ointment of that topology is the high dynamic resistance of the cathode resistor. But it seems to be a can of worms to try to eliminate it through led biasing. It seems like the guy at Nutshell knew what he was talking about so it can't be as simple as requiring a CCS on the cathode circuit. There must be a middle ground here. The only real question it seems to me is if additionally a led can also be used to bias the P-P circuit. And if it can be, something not at all certain, which topology is the best for that. |
#10 |
![]() Just thought I'd update those interested (Sy) what the disconnect in the previous discussion may be about. I finally figured out, sort of, how to put in a CCS in LTspice. So when I tried a CCS in the plate circuit of a PP capacitor coupled circuit it didn't work. But the same circuit worked fine in the equivalent transformer coupled circuit. There's a strange anomally happening where an unuseful voltage develops across the coupling capacitors if the are linked with a common CCS on one side of both caps. I don't much care for the idea of a CCS for each side of a PP so it looks like I'll go with a CCS on the cathode and forego LEDs on the cathode. I knew there must be something that was being left out of the equation. CCS plate loads in PP don't seem much good if the circuit is cap-coupled but work great with interstage trannies. |
| 6T9 push pull with Cathode Coupled input | Brit01 | Tubes / Valves | 5 | 18th January 2009 12:58 PM |
| Push-Pull Cathode Bias Resistors | Kashmire | Tubes / Valves | 5 | 6th January 2008 08:38 PM |
| Separate cathode resistors in push pull output | oldheathkitphil | Tubes / Valves | 1 | 23rd May 2007 05:29 PM |
| The cathode FeedBack in Push-Pull amp | jmartins | Tubes / Valves | 3 | 13th May 2005 04:17 PM |
| Biasing Push Pull Triode amp into Class A | G | Tubes / Valves | 11 | 4th November 2002 03:27 PM |
| Page generated in 0.15899 seconds (83.59% PHP - 16.41% MySQL) with 10 queries |
